Old 03-04-2016, 09:27 AM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Why are there two 'spigots' on my fresh water tank?
I wonder what these two 'spigots' on my fresh water tank do...
Rob
Name:	Fresh water tank spigots.jpg
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is online now   Reply With Quote
Old 03-04-2016, 09:38 AM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
One is the low-point drain, the other is the lower-point drain.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 03-04-2016, 09:46 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Probably the one on the side is tank-manufacturer-installed and the other is Airstream-installed.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-04-2016, 09:54 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The plastic one is the common tank drain. Not sure what the brass one is and the picture is not clear enough to draw any conclusions.
2004 Excursion 4x4
Old 03-04-2016, 10:01 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm thinking the lower one is the low point drain but looking at the lever it doesn't seem what Airstream would use but I could be wrong. It could be the cold and hot systems drain from a common low point drain. The plastic drain on the side is the water tank drain. Is there another low point drain under there somewhere? On my 25fb I have two low point drains; cold and hot but they aren't the lever but a wing nut type of fitting.
Kelvin
Old 03-04-2016, 11:42 AM   #6
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
On my Classic I have a plug that is accessible with the removal of an inspection plate. I use this cause my plastic valve does not work.
Is it possible that someone took out your plug and plumbed in another valve?
DanB
www.campnova.com
Old 03-04-2016, 12:09 PM   #7
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
What KJR said. Tank drain (plastic), low point cold water drain and low point hot water drain (brass). Had me puzzled for a long time until enough folks splained it. Thanks - safe travels. Pat
PKI is online now   Reply With Quote
Old 03-04-2016, 01:10 PM   #8
interstateflyer's Avatar
2017 25' International
Los Osos , California
I have the same drain arrangement on my 2014 23D International. The lower brass one has a red handle which may indicate hot water. Does anyone know off hand if that is the only hot water drain valve.
It is the lowest point on the trailer and I was hoping to plug it for a trip that I'm taking to Yukon/Alaska.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 03-04-2016, 01:25 PM   #9
KJRitchie's Avatar
2008 25' Classic
There you go Rob, you only have 2 valves that could break compared to my 3
Kelvin
Old 03-04-2016, 03:03 PM   #10
RFP
RFP's Avatar
Hurst , Texas
Kelvin
Wow, Kelvin, I feel better now !
And some stuff
Old 03-04-2016, 03:10 PM   #11
RFP
RFP's Avatar
Hurst , Texas
Like yours, ours is a 2014 23D International (Serenity).
So, I hooked up to city water and turned the water on with both spigots open. Water instantly spewed out of the lower spigot (the 'red handle' one), but not out of the one up on the side of the tank. That tells me that the lower spigot is a 'line drain' and not a 'tank drain.'
As with so much about this trailer, the Owner's Manual is essentially worthless.
Anyway, I'm officially de-winterized and just waiting on that legendary Easter 'hard freeze!'
Rob
And some stuff
Old 03-04-2016, 09:51 PM   #12
1998 30' Excella 1000
Livingston , Texas
I'm puzzled. All the rigs I have seen have two low-point line drains. One for hot and one for cold. How can just one drain work for both the cold and hot lines?
Siegmann is offline   Reply With Quote
Old 03-05-2016, 03:54 AM   #13
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The plastic plug on the side drains the fresh water tank (only) and is used when you want to drain the fresh water tank only. The brass valves at the bottom are the low point drains and drain the entire hot and cold water distribution systems (i.e., the pipes.) These are generally used when winterizing.
I'm not sure if the cold water low point drain would also drain the fresh water tank but it would be worth trying in a non-critical setting to see if it does. I do know that the hot water low point drain does not drain the hot water tank so I suspect that the cold low point drain similarly does not properly drain the fresh water tank. All these valves are useful so I'd hesitate to get rid of them, but they are also definitely vulnerable to extensive travel on gravel roads.
Bob Martel
WBCCI# 5766
Old 03-05-2016, 04:27 AM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The white valve is the drain for the fresh water tank. The brass valve with the red handle is a low point drain. You should have another one nearby, plus one behind the water heater. The one near the water heater should be at floor level, inside.
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Why is the water going there? Chatthayer Water Heaters, Filters & Pumps 3 10-15-2012 05:32 AM
two fresh water tanks 1960 Overlander Lothlorian Fresh Water Systems 9 10-28-2010 07:22 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
