Old 03-05-2016, 12:02 PM   #15
1998 30' Excella 1000
Livingston , Texas
Well, RFP, please let us know if you actually have two low-point drain valves, in addition to the side mounted tank drain valve. It would be good to close the loop on your original question.
Siegmann is offline   Reply With Quote
Old 03-05-2016, 01:19 PM   #16
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Okie dokie... Here's what I found: Under the trailer there are only the two drain 'spigots' shown in my first post's photo. I can't find any other drain/spigot other than those two outside the shell.
However, inside the rear storage compartment - to the far right of the door - there are two obvious drain valves... one white PEX the other red PEX. Both exit the shell through the floor and are easily seen under the trailer.
So, I guess that I'm left to believe that there are three 'low point drains' ... two inside the storage compartment and one at the fresh water tank.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 03-05-2016, 02:22 PM   #17
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Go to the Airstream website and send them an email and tell them what you found and to have them clarify.
Airstreams are a lot more complicated than our Casitas.
Kelvin
Old 03-05-2016, 03:45 PM   #18
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I also have 3 low point drains, but two are under the trailer. The third is in the outside storage locker. Airstream told me the one in the locker is for a portion of the hot water system that the low points would not drain. Of course I also have the plastic tank drain under the trailer between the wheels.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-21-2016, 11:47 AM   #19
2016 25' Flying Cloud
stratford , Connecticut
We have a 2012 16' Bambi. One of our low point drain valves has broken off. Has anyone experienced or repaired this? Thanks.
patnal is offline   Reply With Quote
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Why is the water going there? Chatthayer Water Heaters, Filters & Pumps 3 10-15-2012 05:32 AM
two fresh water tanks 1960 Overlander Lothlorian Fresh Water Systems 9 10-28-2010 07:22 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
