Old 04-30-2002, 08:50 PM   #1
ramoore53's Avatar
Question White water tank drain
I have a 1975 Excella 500 and would like to drain the fresh water tank . Is there a way to do this without pumping it out with the trailer water pump?
R.Moore
ramoore53 is offline   Reply With Quote
Old 04-30-2002, 10:13 PM   #2
Removing water from any tank.
It is possible to remove water from a tank by several methods, depending on how the tank is plumbed. The first method is to pump tank with RV pump as installed. Next is to pump with 120volt booster water pump, or connect source of air to fill inlet and allow water to be pushed out any water outlet on sinks or tub, or finally connect a large container that is connected to vacuum pump and suck out holding tank. A refrigeration vacumm pump does a great job for this task. The fitting for using air to blow out the air is available at Wally world and most rv places. What is the problem requiring the removal of water??
Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 05-01-2002, 05:46 AM   #3
ramoore53's Avatar
Frank,
Thank you for the help and infoemation,
As to why I need to drain the tank. I purchased the trailer in February at the time the white water tank was 50% filled with a water antifreeze mix, I need to get that out so the tank can be filled with drinking water.
Thanks again,
R.Moore
Old 05-01-2002, 06:20 AM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If you have the owners manual you might be able to find where airstream installed a valve to drain the tank. It is usally under one of the mid coach cabinets and my be below the level of the floor. If you look under the trialer in the middle you may see a blck tube sticking out thru thre skin. Not the one in front of the roadside wheelwell, this is the AC drain, but just like it. the drain valve is above that tube inside the rig. Good hunting.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 05-01-2002, 10:08 AM   #5
83Excella's Avatar
1983 27' Excella
Airstreamville , Kansas
If you dont see a tube as suggested look for a square panel maybe 5x5in drill out the rivets and there may be a screw drain plug on the tank. You can remove the drain plug and make a drain tube using the same size threads and a tube that extends below the skin. Thats how I found the one on my Excella.
John
83Excella is offline   Reply With Quote
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 06:45 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
How cold for winterizing? ipso_facto Our Community 27 12-03-2003 04:56 PM
Water tank drain Craig 1978- 1979 Excella 500 8 08-24-2002 09:02 AM
White water tank cleaning... Andy R Fresh Water Systems 9 05-17-2002 08:14 PM
