Old 08-23-2010, 10:15 PM   #1
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Which Water Supply Inlet to Use?
My trailer has 2 fresh water inlets. The one that has always been used is the inlet at the rear bumper. The one that has never been used is the underbelly hose reel next to the underbelly electrical umbilical wheel. I asked my dad years ago why he did not use the underbelly hose reel and he said that was only to be used for hooking in to another trailer's water supply when at a rally. I don't know if that is accurate. I thought about using the hose reel on my last trip but decided against it as the hose looks old and I didn't want to chance a water leak from an old gasket or blown hose. Those of you who have both inlets what do you do?
4RXLA is offline   Reply With Quote
Old 08-23-2010, 10:22 PM   #2
x
XXXX , XXXX
Dougsale Either connection will work. Both should have a check or one way valve on them so water will not flow out of one if the other is used. Once you hook up and turn on the water make sure the check valve is working and no water comes out of the other connection. I always used the hose reel because it was very easy to put away the hose to travel.
wasagachris is offline   Reply With Quote
water inlet to black water tank blocked mbarker Waste Systems, Tanks & Totes 4 11-22-2009 08:54 PM
New water tank, new supply tube Globie64 Fresh Water Systems 0 10-17-2009 01:15 PM
High pressure water supply adonh Fresh Water Systems 3 09-03-2009 12:51 PM
Need new water inlet like this! coffeydelsol Fresh Water Systems 5 06-19-2009 11:46 AM
water supply crimp ring Lido&Linda Airstream Motorhome Forums 6 10-23-2003 06:58 PM
