Old 01-21-2008, 10:13 AM   #1
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Which type of Pex fitting to use?
I have some plumbing to do in the trailer, need to replace the line to the water tank with Pex. Which fitting should I use?
Sea-Tech
Shark Bite
Quest
Confused
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 01-21-2008, 10:35 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I am using the fittings that I purchased from Lowe's which I believe are Sea-tech. Everything is plumbed but I haven't tried the water yet because the outdoor temps are 7 degrees today. The fittings are extremely expensive but easy to use. They are also rather bulky. I'll be a sceptic until the water test is done.
Many others on the board have used the Shark bite and Quest. Have not heard any negatives except for the price. I believe the Shark Bite fittings are available at Home Depot. Seemed to be about the same price/construction.
crispyboy is online now   Reply With Quote
Old 01-21-2008, 11:41 AM   #3
DFK
DFK's Avatar
I replumbed using Flair-It fittings. Not as easy to use as Sea-Tech or Shark Bites. My decision was based solely on personal preference. I choose the Flair-It's because in my mind they seemed to provide a more secure mechanical seal. Sea-Tech or Shark Bites are probably just as secure since they are all approved fittings. I'm only chiming in because I didn't see Flair-It fittings on your list and wanted to suggest that you include them as another alternative worth considering.
DFK is offline   Reply With Quote
Old 01-21-2008, 11:53 AM   #4
DFK
DFK's Avatar
Oops! Reread you post. If you are replacing a section of copper pipe with pex and will be connecting the pex to the remaining copper plumbing, I can recommend Shark Bites. A section of the copper water piping in my house froze and split last year. I cut out the split section and replace it with pex using Shark Bite fittings. No problems with the fittings in over year with the line fully pressurized over that period. The Shark Bites were easy to install and to remove and reinstall when I cut the pex two short.
Old 01-21-2008, 12:04 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I had two Sea-Tech leak, they can't take too much out of alinement
'77 Sovereign Intl 31' CB
Old 01-21-2008, 12:15 PM   #6
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
I played around with the Shark-Bite demo at HD. It is really cool how you can attach them to either copper or Pex by just pushing them on... same fitting works for both.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 01-21-2008, 12:34 PM   #7
1986 25' Sovereign
Allegan , Michigan
PEX Fittings
I had to replace the water heater on my 1986 25 foot center bath and elected to use "crimp" fittings. I heard that the others might leak due to road vibration - no personal experience on that point. Anyway, those fittings are lighter and smaller that the others, as well as costing less; downside is the crimp tool and the space it takes to use it.
I have put about 5000 miles on with no problems so far. One other observation - PEX and Polybutylene (PB) fittings are close to the same size; if your trailer has any PB tubing you will need a transition fitting which is a bit unusual. (I learned more on my project than I ever wanted to know!)
Good Luck
Whit Nash
rwnash is offline   Reply With Quote
Old 01-21-2008, 12:44 PM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have been slowly replacing our copper with Pex. I love the (pricey but worth it) Shark Bite. It is especially usefull when you can't use two hands to make the connectios.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-21-2008, 12:46 PM   #9
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Whit-
I have to agree with you on that one. Crimping for me was the only way to go. It doesn't have much to with cost, but rather the fact that it makes for a fail-safe connection. The only drawback as you mentioned is the space needed to fit the crimping tool. I have found that with a little thought before hand replacing the whole water system in the Tradewind was very quick and simple.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-21-2008, 12:56 PM   #10
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
How much are the shark bite fittings?
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 01-21-2008, 01:05 PM   #11
1967 28' Ambassador
1970 29' Ambassador
$6-$8
Steve & the crew
Old 01-21-2008, 01:08 PM   #12
Thanks!
I am intrigued that it can be used on copper and pex! I need to patch an area, short term, for this summer and will give it a try.
Old 01-21-2008, 01:15 PM   #13
One other question.........what size copper line do we generally have in our Airstreams?
Old 01-21-2008, 01:50 PM   #14
1967 28' Ambassador
1970 29' Ambassador
The stuff in mine was 1/2"
Steve & the crew
Re: Fitting Door Panels fr8tshaker Off Topic Forum 4 03-02-2007 06:34 AM
Bayonette Fitting on Dump The Flintstones Waste Systems, Tanks & Totes 5 10-16-2006 09:56 AM
Help! 1/2 x 3/8 x 3/8 push fitting glacierrunne Fresh Water Systems 7 06-05-2006 10:04 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
