Old 12-27-2014, 09:21 PM   #1
2013 28' International
Bozeman , Montana
Which Pentek filter
I have a 2013 International that has a Pentek GS-10ro under sink water filter. Our Airstream is stored out of state and I'd like to get a replacement filter ordered for it ASAP. We will be heading down to AZ soon to be using it and I'm not sure of the specific filter. There is a GS-10ro-B, GS-10ro-C, GS-10ro-G, etc. with different size fittings.
Has anyone ordered a replacement for a newer trailer and know which one is the correct model?
Thanks!
HeadWest is offline   Reply With Quote
Old 12-28-2014, 05:24 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question h2o filter
Is this the one?
I put an Aquasana unit on our kitchen sink and was considering doing the same for the Classic.
ROBERT CROSS is online now   Reply With Quote
Old 12-28-2014, 08:08 AM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey Bob. Are you happy with the Aquasana filter system ?? I was looking at it and find it interesting. With all of your travels do you find it works well with the varied water quality we find at campgrounds ?? Would appreciate your personal, from experience, review.
Thanks and Happy New Year, See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-28-2014, 09:13 AM   #4
Bozeman , Montana
The photo in the link is what it looks like but all the different versions look the same. They apparently put the same label on each although they have different thread sizes on the ends. Hopefully someone has ordered on for a newer Airstream and knows the correct one.
Old 12-28-2014, 10:04 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
maybe this one with 1/4" fitting
Pentek Inline water filter
Alan
A W Warn is online now   Reply With Quote
Old 12-28-2014, 10:46 AM   #6
More than happy with the three stage unit we installed in the house. Most noticeable for coffee making. Completely removes all foul smells,(algae blooms), and taste.
No treatment tastes at all. After a year of use I'm about to change the cartridges for the first time. Very little sediment in our city water supply. Well water at campgrounds may shorten the life considerably.
I was/am considering the two stage unit for the trailer. My only concern....will the water pump supply enough pressure to for an acceptable flow rate?
Right now we are still bringing our filtered drinking & coffee water from home.
Old 12-28-2014, 11:15 AM   #7
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I'm pretty sure this is what you want. Make sure you remove your old fittings from the previous filter.
https://www.filtersfast.com/P-Pentek...ine-Filter.asp
Thanks!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 12-28-2014, 12:23 PM   #8
retired USA/USAF
2001 30' Excella
Thanks Bob. I thought you were referring to a unit installed in your AS. Sorry 'bout that. We have a Reverse Osmosis system at home. Works nicely and was thinking of what could be done on a small scale for use in our AS. So, I guess, still pondering.
Roger in NJ
TAC - NJ 18
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
