Old 06-13-2010, 06:04 PM   #1
1971 31' Sovereign
halifax , Nova Scotia
Where is the city water connecter?
Hello all!
I just purchased my first air stream....its a '71 31 foot sovereign land yacht. All the outside compartments but 2 were seized. I managed to get them all open except the one panel thats right under the tub on the door side. For the life of me I cannot find the place to hook up the garden hose to in order to get the water working. Is it in the compartment that I can't get open? Or where is it? Maybe its gone.....
I've searched the forums the best I could and couldn't find anything relevant. Unfortunately I didn't get a manual for the trailer either so i'm going in blind. Any insight would be great! Thankfully there is a lot of good information on this site!
Thanks!
kerver is offline   Reply With Quote
Old 06-13-2010, 06:18 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Where in the city water connecter?
Greetings Kerver!
Welcome to the Forums and the world of Vintage Airstream ownership!
On most 1970s era Airstreams as well as many earlier models, you will find the city water connection on the streetside rear bumper support between the bumper and body - - it should have a white tethered cap over the inlet.
If you are looking for an owners' manual, reproductions are available through the Airstream store at this link.
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
Old 06-13-2010, 09:20 PM   #3
tinhutjohn
tinhutjohn's Avatar
1974 29' Ambassador
London , Ontario
Images: 8
On my 74 it's on the street side on the rear bumper support beside the sewer cap.
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Old 06-14-2010, 05:45 AM   #4
1971 31' Sovereign
Thanks to both of you for your replies!
I still haven't located it....however there is a copper pipe that has been cut off in the area of the sewer cap. Its quite skinny.
Old 06-14-2010, 06:18 AM   #5
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
copper tube
On my 66 tradewind, there was a 3/8" copper tube left rear with a hose fitting on the end. Could be the same type hook for you. The tube and electric hook came out of the bottom through a piece of PVC pipe.
raveson is offline   Reply With Quote
Old 06-14-2010, 02:14 PM   #6
1971 31' Sovereign
Ok everybody! After taking a better look at the weird skinny pipe I had mentioned earlier it appears that it was maybe an add on as it is screwed into where the garden hose would go. It's seized on there though so I think I will have to try to attach a new connecter to the copper pipe.
Thanks for all the input! Hopefully I can get iworking on this soon so I can find out if the water system actually works. The electricity works and thats all i'm certain about at this point!!
Cheers!
Old 06-14-2010, 02:57 PM   #7
Yhottys's Avatar
1960 24' Tradewind
1961 16' Bambi
Oakland , California
Things Are Looking Up!
Kerver,
You've got at least two things going for you: the electricity is working and you've located your city water inlet!
It took us five years to figure out why the water kept pouring out the back of our '74 Tradewind whenever we hooked up to city water! As far as we knew all of the valves were closed and there were no broken pipes. We just discovered a valve waaay down deep INSIDE in the rear bath vanity that was open. We felt like total idiots and were more than a little embarassed.
The folks on Airforums are incredibly helpful and generous with their knowledge. Welcome and congratulations on your new Airstream!
Gemma and Murray
Yhottys is offline   Reply With Quote
Old 06-15-2010, 03:08 PM   #8
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Kerver!
The photo below is one that I sourced from the Photo Albums here on Airforums. It shows the typical city water inlet for 1970s coaches.
Kevin
Kevin D. Allen
AIR #827
Old 06-16-2010, 05:55 AM   #9
1971 31' Sovereign
Thanks overlander!
I have the part that screws onto the frame(only mine has come away from the frame). I don't have that piece that screws in with the cap. Instead I have a longer copper pipe with an elbow in it that screws into that spot. I will take a picture hopefully later on today and show you what I mean. I'm hoping I can just attach another female connector to what is there!
Cheers!
City Water hookup & Fresh Water Tank? Driver1 Fresh Water Systems 3 02-17-2009 03:28 PM
Fresh water tank fills when hook up to city water Jonah On The Road... 17 09-24-2008 01:23 PM
Connected to city water...NO WATER! Sovereign86 Fresh Water Systems 7 06-13-2007 12:00 PM
City Water Regulator odfarley Fresh Water Systems 2 08-26-2003 10:28 AM
City water 53flyingcloud Fresh Water Systems 2 07-11-2002 12:08 AM
