Old 12-21-2003, 05:22 PM   #1
1989 34' Limited
southern , ontario
Where do these water pipes go?
The water hose bib that enters my 34 splits into 2 pipes one heads towards the washroom and toilet the other appears to cross to the other side of the trailer.
Does any one know where these two pipes end up?
I would like to install a filter system, drawing all the water from the fresh water holding tank with the 12Vdc pump, at the same time the fresh water supply would only go to the holding tank and not to any other part of the trailer.
Thanks for any info.
letsgo is offline   Reply With Quote
Old 12-21-2003, 07:56 PM   #2
WayWard Wind's Avatar
2004 25' Safari
Not real clear what you're looking at, but I would think it might be your cold water inlet to the water heater.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
