Old 05-03-2010, 07:44 AM   #1
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
What's your record, for # of leaks found in the spring?
I had 6.
One on the toilet supply line
One on the pipe from the water pump to the rear
4 on the tub cold water supply.
All fixed now. Next fall, the winterizing procedure will be THOROUGH
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 05-04-2010, 03:49 PM   #2
Brow324's Avatar
2007 27' Safari FB SE
Scurry , Texas
one here....just the moen water filter under the sink...2nd time it's leaked.
this time I removed it permanently and capped the line to the filter. going to an outside filter from here on. If that one leaks at least it's outside.
'07 27 FB - H.A.
Brow324 is offline   Reply With Quote
Old 05-11-2010, 05:39 AM   #3
pageclot's Avatar
1976 27' Overlander
Images: 21
I found a leak in the valve bypassing the fresh water filter as well. I'm going to bypass the bypass.
_____
Kevin and Leah
Old 05-11-2010, 07:04 AM   #4
Isadora's Avatar
1976 Argosy 24
Joplin , Missouri
So far, zero....keeping all fingers and toes crossed! (hard to walk that way tho)
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
http://chaosinature.blogspot.com/
Isadora is offline   Reply With Quote
I may hold the record ? bertro Off Topic Forum 7 10-22-2009 08:16 PM
Record Breaker Air2Go Our Community 0 05-31-2009 01:20 PM
A new record! eljay Off Topic Forum 1 02-26-2006 01:46 PM
A new Record roadeo Forum Admin, News and Member Account Info 8 07-14-2004 08:19 PM
