Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-27-2009, 05:56 PM   #1
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Question What's this for?????
Found this manifold and shut-off valve assembly leaking during Spring get ready this season. The leak has been repaired but Winter shut down is approaching and I still don't know the purpose of the unit. The brass fitting is a one way valve. It's located under the bathroom sink between the cabinet and skin. I found it in the plumbing schematic but no mention of it's function.
HELP
Name:	Water leak 003.jpg
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 09-27-2009, 06:13 PM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Boy you got me on that one.
Can you give us an idea of where the pipe goes on either side?
Never seen a check valve that did not have a hinged clapper in it.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 09-27-2009, 06:21 PM   #3
Usually Sleepy
Profile:  1973 27' Overlander
1972 Argosy 22
East Haven , Connecticut
Images: 16
I've seen check valves like that before, but never as a bypass of a shut off valve.
I cannot come up with a reason to do it, however.
biggoofball is offline   Reply With Quote
Old 09-27-2009, 06:46 PM   #4
finalcutjoe's Avatar
Profile:  2008 30' Classic S/O
Dearborn , Michigan
Robert,
this looks suspicously like my city water shut-off and inline backflow preventer... check out this thread:
City water inlet shut-off valve?
basically, keep it closed, except when winterizing
-J
finalcutjoe is offline   Reply With Quote
Old 09-27-2009, 06:53 PM   #5
CLOUDSPLITTER
W.N.Y. , "
Images: 52
Question
The line runs from the city water connection to the crapper.
Thanks for the link Joe, the shut-off valve has been in the pictured position, (open), since we got the trailer. We have never been hooked to city water, dockers at heart, nor have I done anything with it for winterizing.
SO WHAT DOES IT DO???
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 09-27-2009, 07:28 PM   #6
HowieE's Avatar
Images: 11
The way it is drawn on the Airstream diagram it is a backflow preventer and the hand valve should be CLOSED to keep your pump from backflowing to the city if the city pressure drops.
Old 09-27-2009, 07:56 PM   #7
CLOUDSPLITTER
W.N.Y. , "
Images: 52
Thanks Howie,
We have never been "hooked-up" so that wouldn't be a problem.
But what a PITA to get to for those who go both ways.
It's always been open, any reason to change for Winterizing?
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
