Old 01-16-2014, 02:17 PM   #1
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
what's first?
I have a question. On my water connection, if I look into the pipe with the garden hose removed, all I see is a spring. There is nothing to stop it from falling out. What is this?
terrencecolp is offline   Reply With Quote
Old 02-08-2014, 06:28 AM   #2
1976 25' Tradewind
Tulsa , Oklahoma
After ruling out it being part of a check valve, It must be there to keep a filter screen from going down inside my plumbing. The screen must have just fallen off sometime when I disconnected the water hose.
I'm redoing my plumbing with copper tubing and Shark Bite fittings. Am I making a poor decision by not reinstalling a water pressure meter? I think my flow resistor does the same general thing.
Old 02-08-2014, 06:46 AM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
You're better of replacing your plumbing with pex tubing & crimp rings & fittings. It'll be a lot cheaper & easier in the end. Skip the built in pressure regulator & use an inline version at the spigot in the campground. These are easily replaced when they fail.
Colin
Colin H is offline   Reply With Quote
Old 02-08-2014, 07:24 AM   #4
2013 20' Flying Cloud
Cream Ridge , New Jersey
Colin
X2 what he said. also consider the external in line water filter. Much easier to access for reverse flush or replacement.
Joe Palmieri is offline   Reply With Quote
