Old 01-14-2003, 12:14 PM   #1
Unhappy What Water Hoses to Bring?
Many lists recommend 2 water hoses, one 25' and one 50'. Hoses consume alot of storage space. Are 2 hoses really necessary, and why?
rmmm68 is offline   Reply With Quote
Old 01-14-2003, 12:37 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I think it depends on where you are going & the facilites that will be available.
If you are going to a developed campground with full hook-ups, it may not be necessary to carry both. However, if you are going to a Rally that may not have full-hookups for every trailer, the extra length of hose should at least allow you to hook into water up to 75 feet away.
We have attended several rallys where we have needed to do this...also with electrical.
Shari
Below is a photo of a rally where we needed those extra hoses...
Old 01-14-2003, 12:45 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Don't forget to take your unrestricted Y connector. You may need it to interconnect many units to one faucet. This is standard at International and some of the bigger region rallies. This is also why you need the two hoses. The hose you tap into with your Y connector may be far from your water inlet.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-14-2003, 12:49 PM   #4
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks Brett...I forgot!
Shari
Old 01-14-2003, 12:53 PM   #5
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
No Problem Shari!
I also forgot to mention that you should mark your stuff with your WBCCI number because as the say at the airport "all bags look alike" so do all hoses.
You may also need to lend a hose where the 2 hoses that were brought by others is still not long enough somewhere else.
Brett G
Old 01-14-2003, 12:56 PM   #6
InsideOut's Avatar
1956 22' Safari
Images: 108
I also forgot to mention that you should mark your stuff with your WBCCI number...
Good idea Brett!
We haven't had a problem, but we haven't had as much experience as you....yet!
Shari
Old 01-14-2003, 01:01 PM   #7
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
One year in Rapid City we had to pull out of International due to the heat. Were were in the middle of a row, so taking our hose would have left everyone downline form us without water.
We were just moving across the street to a comerccial campground, so when the rally was breaking down we just went back and picked up our hose. We knew it was ours because it was marked.
I reccomend marking all of the items, clothing, and such that you frequently carry. That way at a rally you have a real good chance of getting it back if you lose it or leave it behind.
Brett G
Old 01-14-2003, 07:39 PM   #8
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I don't know whether it is Murphy's Law or coincidence, but I have found that the 75' of water hose recommendation is a bare minimum. One way or another, I always seem to be the first trailer that must connect to the water valve and need at least 100' just to get that far. Over the past five years, I have added a 50' section of hose to my parts bin (carried in Rubbermaid containers in the rear of my Suburban) each year, and now find myself with 250' of hose - - and last year 200' of that hose was used filling gaps between my coach and neighbors on either side.
I would also suggest carrying a spare no-restriction "Y" connector as well as a good supply of hose washers as they can be at a premium when at campgrounds or rally sites. Hose washers and "Y" connectors don't ever fail at a convenient time - - somehow, mine seem to like Sunday mornings at about 4:30 a.m.
Something that some would recommend against, but I find quite useful on my coach is a fitting that allows me to turn off the water supply to my trailer without impacting the water being sent out the "Y" to my neighbors. This device provides two benefits - - you can leave the trailer without concern about a pipe springing a leak in your absence, and you can make quick repairs to your coach (such as changing water filters) without interrupting service to the neighborhood. Depending upon how you route your "Y" and associated hoses, it is even possible to permit totally disconnecting your coach without interrupting others sharing the connection - - for example if you want to tow your coach to a car wash to prep it for the Vintage Concourse.
Kevin
Kevin D. Allen
AIR #827
Water System Woes swebster Mechanics Corner - Engines, Transmission & More... 5 08-02-2003 08:21 PM
water system mystery garymacf Plumbing - Systems & Fixtures 4 06-21-2003 11:50 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Water hoses ALANSD Mechanics Corner - Engines, Transmission & More... 8 01-26-2003 10:46 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
