Old 04-22-2009, 06:34 PM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
what size is this?
Ok, I was just doing some plumbing repairs, and was getting confused over the pipe sizes installed. I think the source of the confusion is that some pipes are referenced by inside diameter, and others, by outside. Why it isn't more universal, I don't know.
anyway, I took off a flared connection to my shower valve, so I could bring it to the hardware store and get a positive identification. Ok: its 3/8ths od copper. great. It just seems odd, though, by today's standards...aren't most faucets 1/2"fip? I'm thinking of a future re-do of the plumbing...most common it seems today to use the stainless flex-connectors for faucet risers, and they're all 1/2".
anyway, the connection on this shower faucet is 3/8 on the inside...but also threaded on the outside, but its way bigger than 1/2". I didn't see anythhing in the store that looked like it would adapt to 1/2". nor did they have a 3/8 to 1/2. Was this a typical size in the old daze?
Oh, yeah, almost forgot: and why did they use a different sized pipe for the hot water side? not the faucet risers...but the rest of the run from the water heater...its 3/8 ID. I see they have pex in that size...but in most retrofits I see here, it looks like people are using 1/2" for both the hot and cold sides.
Name:	IMG_2509 (Large).jpg
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-22-2009, 06:43 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The outside thread that takes the nut to secure the faucet to the wall is not a tapered pluming size and you will not find a plumbing fitting to fit it.
2004 Excursion 4x4
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
What size WH Gbass Water Heaters, Filters & Pumps 18 06-19-2012 09:23 AM
What size mok Member Introductions 4 05-31-2008 05:50 PM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
What size do I need? Tin Hut Batteries, Univolts, Converters & Inverters 3 04-07-2004 06:30 AM
