Old 10-23-2006, 11:38 AM   #1
kamo's Avatar
burbank , California
what pipes to use?
Hello,
I'm re-plumbing a 62 Bambi. There were pieces of copper pipes in there, but I've heard it's easier to use plastic.
I saw some pictures, they look like transparent ~1/2, flexible-ish pipes. What are those called and where can I get them?
Kamo
kamo is offline   Reply With Quote
Old 10-23-2006, 11:42 AM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Pex
Hi kamo, do a search for Pex - you'll end up with a ton of information.
Mel
Mel is offline   Reply With Quote
Old 10-23-2006, 12:01 PM   #3
Frank S
peoria , Illinois
Hi kamo--The transparent flexible-ish pipes you saw were 5/8" ID plastic that you can buy in any big box, or hardware. Just cut out the bad copper in your A/S, slide the plastic over the copper, and secure with a stainless steel screw clamp. I have used this method for all rework, and it has been leakfree for 18 years. Unlike the high water pressure in your home, the pressure in your A/S is about 45 psi, so the plastic with clamps works just fine. Worked for me.--Frank S
Frank S is offline   Reply With Quote
Old 10-23-2006, 02:58 PM   #4
kamo's Avatar
Thanks for the replies!
It looks like Ace hardware sells the 5/8" PEX pipes.
Kamo
Insulate those hot water pipes. LTD30 Fresh Water Systems 2 06-09-2006 03:23 PM
Bad Problem w/ Water Pipe rroessler Fresh Water Systems 20 06-05-2006 11:23 AM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 10:56 AM
Two PVC pipes? John Fresh Water Systems 11 12-06-2002 04:59 PM
getting to plumbing maznblu Fresh Water Systems 4 06-05-2002 07:21 PM
