Old 12-01-2009, 08:12 AM   #15
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
If the water pressure inside the trailer
gets too high, it opens and lets water
out through the drain hose. If it is letting
water out continuously, then it is stuck
open. Mine went bad the same way. I took
the old one apart and it was full of deposits
and corrosion. You can, if you choose, rid
yourself of it and do the job with a modern
supply side regulator.
kennethowens is offline   Reply With Quote
Thetford waste valve replacement Safari64 Plumbing - Systems & Fixtures 6 02-24-2012 08:32 PM
City/water tank check valve gunner Classic Motorhomes 5 10-03-2011 06:49 AM
