Old 09-10-2014, 09:21 AM   #1
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
What is the OEM under sink water filter?
When we picked up our 25FB there was a water filter in the box of goodies, but no info on what it was or where it went. I'll admit it....I couldn't figure out what it was so I tossed it. I now know it was suppose to be installed under the kitchen sink (there is apparently a winterizing pipe installed in it's place). I would like to install that filter since DW is very picky about water taste, but I cannot find any info on the filter. I'm sure there are several companies that make them....I just a little push in the right direction. Is it a #3 filter?
Landrum is offline   Reply With Quote
Old 09-10-2014, 10:00 AM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Pentex Water Filter
This is what is under our kitchen sink:
Amazon.com - Pentek GS-10RO-B 10 inch x 2 inch inline Water Filter - Replacement Undersink Water Filtration Filters
Bob Martel
WBCCI# 5766
Old 09-10-2014, 10:16 AM   #3
Landrum's Avatar
Great. Thanks.
Old 09-10-2014, 10:26 AM   #4
mefly2's Avatar
2015 25' FB Eddie Bauer
AAB has given the same specs as does ours ...
Old 09-10-2014, 01:37 PM   #5
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Landrum, here is a less expensive source for those filters.
Filters Fast - Search Results for Pentek GS-10RO Inline Water Filter
One more thing. I believe the "-B" designation is for the 1/4" opening. My filter requires the 3/8" opening (the"-C"). Make sure of your diameter before you order and don't make the dumb mistake of ordering the wrong size (1/4") like I did.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 09-10-2014, 02:18 PM   #6
Landrum's Avatar
I hate plumbing. I mean I love plumbing....I hate working on plumbing. I pulled the winterizing section out and it has 3/4" outside diameter male threads on each end. I'm not sure 1/4 or 3/8 will fit. Guess I'll go buy a couple different size filters for some trial and error ( which is usually more error for me which is why I hate working on plumbing).
Old 09-10-2014, 02:34 PM   #7
Chelsea , Michigan
Images: 12
Take your winterizing tube section to Lowes and you can figure out the proper fitting sizes there. They may very well have the filter in stock or could order it or you could go home and order online once you are sure of the proper size fitting.
Bob Martel
WBCCI# 5766
Old 09-10-2014, 03:13 PM   #8
Branson , Missouri
Landrum, my addled brain takes a bit to get started, but I remembered (after your last post), that there's a nylon transition piece that you will also need.
Your dealer should have taken care of that, but…
The transition will need to be from that 3/4" od to a 3/8" or if you can find it, a 1/4".
Perhaps Lowes or HD has these transition pieces, but don't get your hopes up too high.
2013 Suburban 2500
2011 23 FC FB
Old 09-10-2014, 03:39 PM   #9
Landrum's Avatar
I see now where you can buy these filters in a kit with the adapters and a winterization Line. I'm just going to buy one of these kits and save myself a lot of trouble.
Old 09-10-2014, 03:40 PM   #10
2011 30' Flying Cloud
Arvada , Colorado
We a Moen faucet and here is the filter we use. Available on Amazon for about $29.00
Moen 9601 Choiceflo, 9600 Replacement Filter
Jack46 is offline   Reply With Quote
Under sink water filter Jfed Water Heaters, Filters & Pumps 11 09-17-2013 11:27 AM
Delta Under Sink Water Filter evanskl Water Heaters, Filters & Pumps 0 05-22-2009 11:07 AM
under sink water filter advise Safari64 Water Heaters, Filters & Pumps 3 04-08-2009 07:28 AM
Under sink drinking water filter wacnstac Water Heaters, Filters & Pumps 7 04-05-2006 03:01 AM
Need a Water filter under sink w9det Water Heaters, Filters & Pumps 7 06-29-2005 06:15 AM
