Old 04-02-2012, 07:55 AM   #1
1968 28' Ambassador
Westford , Massachusetts
What is it - pressure reducer?
This hunk of metal has a drip coming out of it. I'm going thru the plumbing and want to replace anything bad but I have no idea what it is...
68ambassador is offline   Reply With Quote
Old 04-02-2012, 08:01 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Possibly a check valve to prevent water from flowing out of the inlet when using the pump. Most check valves have an arrow on them to show the direction of the water.
Richard
Old 04-02-2012, 08:02 AM   #3
Tradestream's Avatar
1962 24' Tradewind
Panama , New York
That looks like a checkvalve or backflow preventer. The pressure regulator is that bell looking thing to the right with the bolt sticking out. Hope this helps
Dan
Tradestream is offline   Reply With Quote
Old 04-02-2012, 08:29 AM   #4
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
Looks like backflow preventer. You can buy replacement at Lowe's or Home Depot
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 04-02-2012, 08:33 AM   #5
Kevin245's Avatar
Ditto the backflow/check valve theories.
Eleanor Roosevelt
Old 04-03-2012, 07:42 AM   #6
1968 28' Ambassador
thanks everyone. moving to pex and plastic
Thanks I'm going to run with that. I am thinking I'll replace as much as possible with pex/plastic-any ideas thoughts or suggestions?
Will It Tow It? dscluchfc Towing, Tow Vehicles & Hitches 50 04-27-2012 06:48 PM
Window gone - what happened? jgerardi Windows, Doors, Locks & Vents 17 04-05-2012 06:55 AM
Hot water tank over pressure GettinAway General Repair Forum 7 04-04-2012 08:11 AM
What is it - pressure reducer? 68ambassador Fresh Water Systems 5 04-03-2012 07:42 AM
Caravanning as it should be done MrUKToad Fun & Games 3 04-03-2012 05:46 AM
