Old 09-06-2013, 11:13 AM   #1
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
What is it?
Filling my freshwater tank this morning when a clear piece of plastic tubing About 9 inches long floated out of the inlet on the the stream of water flowing back from the (overflowing) inlet.
Should I start taking things apart?
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is online now   Reply With Quote
Old 09-06-2013, 11:15 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It sounds like part of a filler. I have one like this one from Camping World that has a piece of clear tubing on the end. If the tube came off, especially with water rushing through it, it could end up in the tank.
— David
DKB_SATX is online now   Reply With Quote
Old 09-06-2013, 11:44 AM   #3
twobikes's Avatar
1997 25' Safari
Thanks for the quick response. DW returned to find the vent fan in pieces and me puzzling over this new dilemma ...
That DOES look just like it. I have never used such a thing, but the PO had 13 years with it. I didn't lose that silverware that appeared in my sewer hose one day either.
Can someone tell me it DOES NOT Look like any critical part of the inlet fill assembly?? I have been searching for a schematic of how the inlet box attaches to the fresh water tank itself
PAT & AL MEYER
Montgomery, Alabama
Old 09-06-2013, 11:56 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Pictures?
Old 09-06-2013, 03:09 PM   #5
twobikes's Avatar
1997 25' Safari
Hi Minno
The clear piece I found looks EXACTLY like the clear tube portion on the filler neck that DBK_SATX posted, right down to the taper on t he end. Sorry, I have to bone up on posting pictures.
PAT & AL MEYER
Montgomery, Alabama
Old 09-06-2013, 03:47 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
My first thought was exactly what DBK_SATX posted. I can't think of any other reason a hose in the system would have that sort of taper on the end.
Stephanie
Old 09-06-2013, 06:19 PM   #7
Minno's Avatar
1972 31' Sovereign
We use one of those all the time, and have for years. Never lost the plastic tube off the end though. If the tube that bubbled up out of your tank looks exactly like that filler tube, then you have nothing to worry about. There are no parts in the tank's filler tube assembly that would look like that. The tank's filler tube inside your trailer is either 1 1/4", 1 3/8", or 1 1/2" in diameter. Much larger than what you found.
Old 09-06-2013, 07:27 PM   #8
twobikes's Avatar
1997 25' Safari
YOU GUYS ARE GREAT. THANKS , now on to grey tank sensor....
PAT & AL MEYER
Montgomery, Alabama
Old 09-06-2013, 07:47 PM   #9
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I have one of those floating around in my tank. My new one has a hose clamp on it so there won't be two of them in there.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 09-07-2013, 05:23 PM   #10
Madison , Wisconsin
Can someone send a photo of their fill hose fron inside the trailer to the fresh tank? PO removed prior to me purchasing.
bkoning is offline   Reply With Quote
Old 09-08-2013, 05:49 AM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
That's an odd thing for him to have done. Did he never use the tank, or did he just need the hose for something else and scavenged it?
When you get your new hose hooked up, flush and disinfect the tank thoroughly. Since the hose was gone, you has a great gaping hole in the top of the tank that could have let who knows what into it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 09-09-2013, 07:31 AM   #12
Madison , Wisconsin
A lot of things the previous owner did was questionable. He gutted the main cabin - covered rotted subfloor with laminate flooring, removed a majority of the plumbing (fresh water), and was just using as a rolling tent. He only owned for 1 yr and got in over his head. I'm replumbing with pex, but the dia. of the fill and fresh tank are large and I'm having trouble sourcing a flexible hose large enough so it doesn't pinch when bent. I've found something that will work for now- in order to test and clean the tank, but would like to see a photo of what is 'should' look like.
Thanks for any help.
