Old 05-31-2009, 02:40 PM   #1
JimGolden's Avatar
1977 31' Excella 500
What glue should I use to fix a small crack in my freshwater tank?
Hi everyone,
I have discovered the source of the small leak in my fresh water tank. My tank is L-shaped and at the top of the tank in the inside of the L-angle, I found a very fine crack in the tank.
I discovered this very scientifically; I took my shop vac, hooked the hose to the blower side, made a funnel out of a 2L pop bottle, then lightly pressurized the tank. Had my wife hold the funnel and hose assembly to the fresh water inlet door and I went inside and reached through an access door to find where the air was coming from. The low pressure air worked like a charm
So my tank is the standard white plastic material. I would guess it is polyethylene or polypropylene. What glue should I use to fix this hairline crack? 2-part epoxy? PVC cement? Model airplane glue? I don't have easy access to a plastic welder either. Would prefer to just glue it shut if possible.
There's really not much room to glue another piece of patch over it. I don't think that I really need a patch; the crack isn't even visible to the eye. But you can feel air coming through it. The leak was about a drop every 15 seconds, but I lost probably 10 gallons over a weekend and it's not good for the floor/belly pan. I want to fuse the plastic shut.
I am fortunate in where the leak is located. It is relatively easy to get at. I just need to find out what the right glue is for this. Any help would be appreciated.
thanks!
- Jim
JimGolden is offline   Reply With Quote
Old 05-31-2009, 03:03 PM   #2
Originally Posted by JimGolden View Post
Hi everyone,
thanks!
Glue is a no-no.
For a quick repair, for a "small" crack, fuse it back together with a small "soldering iron." Or, melt some of the same material, scuff the surface, and pour it on.
That tank is a crazy design and it's been obsolete for 30 plus years, so be careful.
I have the drawing for it and no one wants to get involved making it again, unless you order 25 or more.
Old 05-31-2009, 10:44 PM   #3
somefun's Avatar
1974 27' Overlander
Puyallup , Washington
I'm getting ready to repair some cracks in my black water tank (low density polyethylene), and I'll be using Scotchweld 8005. I should know how it worked by this time next week. Copy and paste the following into the search box on Google for some good info on this product:
site:www.airforums.com scotchweld
somefun is offline   Reply With Quote
Old 06-01-2009, 08:15 PM   #4
SteveH's Avatar
Common Sense , Texas
I've had good luck with Household Goop for such uses. It's a very thick silicone that hardens well, and is waterproof.
Old 06-11-2009, 04:22 PM   #5
JimGolden's Avatar
Scotch Weld works great!
Hey Gang,
Just a final report on my tank repair. I looked into that 3M Scotch Weld DP-8005 and it looks to be the only glue in the world made for polyethylene. I couldn't even find it locally. So....I looked online and saw that it was $30 for a tube of it and about another $40 for the applicator tube. So.....I called up a guy I know who is a 3M rep and said "How 'bout a sample?" Dude hooked me up
I cut a thin piece of polyethylene about 1" by 2" by 1/4". Cleaned both the tank and the new piece with alcohol, let it dry, then glued her up. 24 hours later I did my air pressure test and it held just fine. Filled her up and no leaks. It's been holding for days now.
So anyway, if you don't have a hot air plastic welder or other similar tools or access to the place is tight, I think this product from 3M will work just fine. It seems to be a great product. Even if you had to pay the full fare, I think it'd be worth it.
See ya on the road,
- Jim
replacement freshwater tank?? slvrbulit Fresh Water Systems 2 04-17-2009 08:10 PM
Can I fix a crack this big in a bathroom counter? 2Alaska Cabinets, Counter Tops & Furnishings 21 11-06-2008 08:35 PM
I don't want to melt freshwater tank bertro Repairing/Replacing Floor &/or Frame 3 04-11-2008 06:34 PM
How can you tell if your freshwater tank is truly clean? JimGolden Fresh Water Systems 24 10-30-2007 08:44 AM
Is something wrong with my freshwater tank? TitusLivy Fresh Water Systems 11 04-28-2007 09:15 AM
