Old 07-17-2009, 06:05 AM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
What does this valve do?
While on vacation, my potable water tank started leaking. I couldn't get the access panel off because the screws were so corroded. I decided to try to see what was going on from the top down. I took off a piece of what appears to be lead sheeting to peer down by the tank. While I couldn't fix anything from up there, I did see this valve on the left hand side of the picture. I can't figure out what it does. It continues out the bottom of the trailer (as pictured in the last picture..the grey colored tube behind and to the right of the water drain). I did put a new drain in while on vacation, since I could get at that without removing the panel on the bottom (although that wasn't the problem--the bottom drain was). But anyhow, what does the valve in question do?
Name:	valve above potable water tank 2.jpg
ID:	84024   Click image for larger version
Name:	valve above potable water tank.jpg
Name:	drain valve on potable water tank.jpg
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-17-2009, 07:08 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That's a drain. You would open it to let the water out for winterizing.
Old 07-17-2009, 07:48 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes a drain. This type of valve is Turn and Lift to open and turn and push down to close. The turning is just to reduce the friction as the valve starts to move not a treaded shaft.
2004 Excursion 4x4
Old 07-17-2009, 10:48 AM   #4
Becky B.'s Avatar
1964 17' Bambi II
The strange thing about this being a drain....it was under a piece of lead sheeting that was nailed down. It also had insulation over it. I filled my fresh water tank & turned the valve, but nothing happened outside. There is a drain on the outside of the fresh water tank. Would this be a drain for the lines in the trailer? Why would they put it under all of those things?
Becky
1964 Bambi II
1988 Avion 32S
Old 07-17-2009, 02:18 PM   #5
HowieE's Avatar
Images: 12
I doubt the factory installed the lead. Most likely a PO did that to keep out small critters.
If it is a drain for the system you would have to open the faucets and brake the vacuum to drain the system.
2004 Excursion 4x4
Old 07-17-2009, 04:17 PM   #6
Becky B.'s Avatar
1964 17' Bambi II
Makes sense. Thanks for the replies. I think I'll reseal it with something that's a bit easier to remove!
Becky
1964 Bambi II
1988 Avion 32S
How does this valve even operate? OregonArgy Waste Systems, Tanks & Totes 5 04-12-2008 09:29 PM
Only one Thetford Valve? The Flintstones Waste Systems, Tanks & Totes 10 10-09-2006 08:53 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
valve Ga Pockets Fresh Water Systems 6 01-15-2005 12:03 PM
Dump valve ALANSD Waste Systems, Tanks & Totes 4 12-04-2002 06:07 PM
