Old 07-13-2018, 10:55 AM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
What does this go to?
29' 1992 Excella twin bed, Right behind where the city water comes in, street side, the pipe branches and the one with blue tape 90s into the floor just past the on/off valve. It's always been off. What is it for?
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 07-13-2018, 11:01 AM   #2
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Low point drain?
Old 07-13-2018, 11:09 AM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
OMG! Who closed it?
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 07-13-2018, 11:32 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
It is a low point drain, right at the start!
Old 07-13-2018, 11:55 AM   #5
Long Island , New York
Is this your owner's manual?
https://www.airstream.com/wp-content...0110i.arc_.pdf
On p. F-31 [PDF p. 107/222], at the top, the twin-bed illustration would seem to apply to your 29' IMO ["no matter what style"], even though it is entitled Thirty-Two Foot. There is an "X" right where your photo shows the valve/drain.
If you look under the trailer, you should see the blue pipe exit straight down, and water will come out of it when you open the valve.
Cheers,
Peter
PS -- Edit -- Oops just found your earlier thread -- still have the following manual handy?
[click on orange arrow in quote to go there]
Originally Posted by Re-Pete View Post
Thanks to OTRA15's reminder, I took a look at my AS manual and low and behold in section F page 14 there was a drawing showing the Black Tank Flush Assembly, including the Vacuum breaker. Knowledge is power, I've been curled up with the manual all morning.
Pete
Old 07-14-2018, 08:52 AM   #6
Re-Pete's Avatar
1992 29' Excella
Thank you ALL for you help on this.
I suspected it was a drain but it did not show up in my owners manual and I did not turn the page and look at the next length up. It does show it on the 30'. Looking under my AS I did not see an exit hole or tube, but I may have just missed it.
As you may have noticed there's been some previous sub-floor repair work done in that area. Anyway, since I'm replacing this sub-floor the mystery would have been solved at some point, but I really was curious and I knew some of you would know.
This old quest pipe is history also and will be replaced when I begin the rebuild.
OTRA15 (Peter), Thanks for the '92 manual PDF. My manual is also for a 92, but from location of the floor plans it's obviously different. I haven't looked further than the trailer floor plans on Pages F30 and F31 but they are different than mine which are located on pages F19 & F20. It will be interesting to compare and it will be especially nice to have this digital manual on my phone and computer.
Pete
Virginia Beach, VA
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 09:38 AM
Why does front A/C have drain hose but back A/C does not? AccessMaster Airstream Motorhome Forums 9 06-22-2003 08:15 PM
Does anyone tow with a Classic Vehicle? 68 Suburban Tow Vehicles 0 10-22-2002 03:14 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 06:49 AM
Does anyone know #16019? Pahaska Our Community 15 06-30-2002 05:25 PM
