Old 08-15-2009, 10:42 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
What do these valves do?
A PO installed a new kitchen counter unit that makes it very difficult to gain access to the fresh water tank connections. Today I removed a couple drawers so I could poke around a take a few pics. What do these three valves do? I assume one of these is the fresh water drain? Which one?
ID:	85417   Click image for larger version
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-16-2009, 01:16 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The one directly facing the camera in your second pic should be the fresh water tank drain. The other two are water system drains. You should have a couple in the rear of the trailer as well, and one inside the water heater compartment.
Old 08-16-2009, 06:32 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Terry. I opened that valve and nothing happened and I know that tank has water in it. Perhaps, I didn't open it far enough. I'll try again.
1958 Overlander
4CU 1st VP
Old 08-16-2009, 08:31 AM   #4
treeair's Avatar
1971 23' Safari
Bozeman , Montana
What does it say by those pencil arrows on the subfloor? I also have 3 drain valves under the sink and has been a mystery on how to get watr tank to drain as it should.
treeair is offline   Reply With Quote
Old 08-16-2009, 08:38 AM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We had a full tank of water when we picked up our "72 - had probably been in there well over a year (EW!). Nothing happened when we opened the drain, so Chris looked at the drain pipe under the trailer - plugged. He stuck something up there, and, yup, it drained- for over 4 hours!
Try checking to see if the drain is plugged!
Kay
Old 08-16-2009, 08:55 AM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Kay. I'll try that. I opened that valve ALL THE WAY and nothing happened, so that will be the next thing I try.
1958 Overlander
4CU 1st VP
Valves for a 76 Argosy 22 Gambrinus Waste Systems, Tanks & Totes 14 02-22-2008 09:56 AM
testing the valves Dan S All Argosy Trailers 1 05-25-2007 10:41 AM
Dump Valves - Need Help lebolewis Waste Systems, Tanks & Totes 7 09-06-2006 06:52 AM
valves again frederic.c01 Plumbing - Systems & Fixtures 8 06-02-2004 02:30 PM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
