Old 12-27-2010, 02:11 PM   #1
DougZ's Avatar
1972 27' Overlander
Venice , Florida
What am I missing on water intake?
I am a new owner of a 1972 Overlander. It is in very goo shape but the PO was a genius at screwing up repairs. When I opened the fresh water input I found that it goes nowhere. The hose is missing and I can't see where it is suppose to go. I am assuming the worst and thinking that the water tank maybe leaked so he removed the filler hose and vent. I'm not sure yet where the holding tank even is so I'm not sure where to look.
DougZ is offline   Reply With Quote
Old 12-27-2010, 02:22 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
There should be a hose to the water tank from that fitting. The water tank is under the floor and there should be a wholr in the floor to access it. If this is like my 75 TW, the water pump should also be in that picture.
Is it possible that the PO only ran with city water and may have modified the trailer to eliminate the water tank and pump?
Richard
Old 12-27-2010, 02:36 PM   #3
Maybe this might help you.
Old 12-27-2010, 02:37 PM   #4
1971 27' Overlander
Chesapeake , Virginia
I have a 71 Overlander had the same problem. If it is the same as mine look under the edge of the floor out from the water inlet.
VaGem is offline   Reply With Quote
Old 12-27-2010, 02:40 PM   #5
1971 27' Overlander
Mine was next to those copper pipes under the floor. I had a time finding hose to hook them up
Engine Air Intake tomjunw Mechanics Corner - Engines, Transmission & More... 28 12-06-2008 08:51 PM
city water intake fitting broke off Driver1 Fresh Water Systems 18 10-27-2008 10:38 PM
Safari 23 SE - lock fresh water intake? TheThreeSeas 2006 - 2010 Classic (all lengths) 16 02-07-2007 05:03 PM
More intake air GlenCoombe Mechanics Corner - Engines, Transmission & More... 7 02-04-2006 07:15 PM
will atwood drain from cold intake 63air Water Heaters, Filters & Pumps 2 09-14-2005 04:50 AM
