Old 01-09-2011, 09:27 AM   #1
qc1500's Avatar
rozenburg , netherlands
waterlines size
I am rebuilding the inside of our AS after replacing the frame ( De Mazzel! ) some things were broken during the taking apart of the inside.
Also some waterlineconnections. I want to replace some connectors( don't know if this is the wright word) because they came apart. It is copper but i don't know the size of the waterlines.
In europe we use 15mm but i don't thinks this is the correct size. I have some 15mm connectors but they just don't fit.
Can someone tell me what size i need?
Just a small picture of our project one google earth
1974 31ft sovereign international
1976 SMV 520
towed by 2005 Dodge ram SRT-10
qc1500 is offline   Reply With Quote
Old 01-09-2011, 09:30 AM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I think most is 3/8 in.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 01-09-2011, 09:31 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It is likely 1/2 inch. that would be about 12.7 mm. You may haveto replace all the water lines. That may not be a bad thing.
Michelle TAC MT-0
Sarah, Snowball
Old 01-09-2011, 09:36 AM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
sizes are 1/2",3/8" and 1/4",all sizes are inside diameter.If you need a lot of repair I would remove all copper piping and replace with pex. Dave
easyride is offline   Reply With Quote
Old 01-09-2011, 09:48 AM   #5
qc1500's Avatar
Thanks! I don't think i need to replace a lot, at least, i hope The sizes used in europe are all outside sizes over here. Do you know the outside size as well?
1976 SMV 520
Old 01-10-2011, 04:18 PM   #6
easyride's Avatar
1977 27' Overlander
Naples , Florida
5/8-1/2-3/8 is o.d. size. Dave
Old 01-11-2011, 02:08 AM   #7
qc1500's Avatar
What does o.d. size mean? outside?
1976 SMV 520
Old 01-11-2011, 12:05 PM   #8
dznf0g's Avatar
Oswego , Illinois
Outside diameter = OD
Inside diameter = ID
Old 01-11-2011, 06:04 PM   #9
Ottawa , ON
Are you going to use the trailer in Europe? If so, why not stick to the standard there?
Overlander Gaucho pics NicheVintage 1965 Overlander 11 01-28-2011 12:12 PM
