Old 05-30-2007, 08:59 AM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Water valve position question
I have a 74 25" Tradewinds and I need to know how to configure the fresh water system for use. I just bought this trailer and basically know nothing about it. there are 3 valves under the galley sink and I need to know what position to place all 3 in for use. I believe all three are wide open right now as the trailer had been winterized in OHio where I bought it a few weeks ago. How do I get pressure built up with the water pump? Anybody have any ideas for me?
chuman70 is offline   Reply With Quote
Old 05-30-2007, 09:19 AM   #2
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
All three should be closed when you're using the water system.
The two which are close together are for draining the hot and cold lines in the front of the coach. The one which is located under them is to drain the water tank itself. It's connected to the same line that the pump is drawing from, so when it's open, the pump will not draw water.
You might want to check for open drain valves in the rear of the coach and close them before you try pressurizing the system. Check to make sure the drain plug is in the water heater. If there is a filter installed under the sink, make sure it's either off, or bypassed, or has a filter installed. That will save you from some potential water fountains!
Good luck!
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 05-31-2007, 08:43 PM   #3
1974 25' Tradewind
Thank you so much!
Old 06-03-2007, 12:25 PM   #4
1974 25' Tradewind
Hmmmm....tried all of that and still no luck. You mentioned drain valves in the rear. Where might they be?
Old 06-03-2007, 01:02 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
rear drain valve
In my 71 Tradewind it is in the bathroom closet curbside.
Old 06-03-2007, 06:23 PM   #6
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Can you post a picture? It might help us figure this out.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
Check valve (?) Chuck Fresh Water Systems 9 11-03-2002 09:19 PM
water line leak Bugsy1082002 Plumbing - Systems & Fixtures 5 10-30-2002 07:27 AM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
