Old 04-12-2006, 01:31 PM   #15
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Originally Posted by mtnman
I thought that it may be that but was not sure, it looks a lot like a water heater pressure valve. I am not going to put that back in the coach, it was leaking.
well...that's what it is supposed to do...IF there's too much pressure somewhere. might be functioning normally. or it could be broken. just leaving the system pressurized, with the hot water heater on, and not opening a tap for some time (like you might do if you were to turn on the water heater while the rig is in your back yard, and then forget to turn it off, and it sits there running for days or weeks) could cause enough pressure to build in the lines, and trigger this device.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-12-2006, 05:05 PM   #16
mtnman's Avatar
Collettsville , North Carolina
It was leaking out water from the 12 volt pump pressure. The 12 volt pump was kicking off and on is how I found out it was bad.
I still need to know how to adjust that water regulator?
mtnman
mtnman is offline   Reply With Quote
Old 04-12-2006, 05:25 PM   #17
Frank S
peoria , Illinois
Hi mtman--Toss out the old pressure regulator. You will eliminate a lot of potential problems. Go to WalMart and buy a Marshall regulator for $8. in their RV section. Install it on your city water supply, connect one end of your hose to the regulator, and the other end to your trailer.--Frank S
Frank S is offline   Reply With Quote
Old 04-12-2006, 05:30 PM   #18
Frank S
peoria , Illinois
Hi mtman--Forgot to mention the Marshall regulator is preset for about 45psi, which is exactly what your Argosy needs.--Frank S
Old 04-12-2006, 05:31 PM   #19
mtnman's Avatar
Frank,
I just re-installed the old one, it works fine. I also have a small hose type Marshall regulator if I need it though.
mtnman
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
