Old 08-06-2007, 10:15 PM   #1
1974 25' Tradewind
Muscle Shoals , Alabama
Water taste question
Does anyone know how to get the plastic water hose taste out of the water? Is there anything I can do to treat my water hose to remove that awful taste?
chuman70 is offline   Reply With Quote
Old 08-06-2007, 10:52 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
1. Use a hose made for domestic water supply - usually white. Or,
2. Use a charcoal filter to remove the taste. R/O systems use charcoal.
Fyrzowt is offline   Reply With Quote
Old 08-06-2007, 10:59 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Yes, use a white hose, even when filling your water tank. If the taste is from the tank water sanitize the tank with a little bleach, drain then a little baking soda and drain. It probably a good idea to sanitize anyway if you have not.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-06-2007, 11:31 PM   #4
soldiermedic's Avatar
Florissant , USA
You mean I can't use that green hose I been cleaning the gutters out with????
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 08-07-2007, 01:12 AM   #5
1974 25' Tradewind
I have the white potable water hose. It just tastes horrible.
This water is from the city water system. We used a Britta water filter pitcher inside, but still had the same foul tasting plastic water.
Old 08-07-2007, 04:37 AM   #6
richinny's Avatar
2011 34' Classic
how does it taste before it goes into the hose and how does it taste after the hose but before it goes into the trailer?
Old 08-07-2007, 04:44 AM   #7
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
From whom did you purchase the white hose?
Have you purged your fresh water tank?
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 08-07-2007, 04:46 AM   #8
2007 25' International CCD
Arlington , Virginia
Sounds like the case of the missing in-line water filter to me.
Streamer1 is offline   Reply With Quote
Old 08-07-2007, 04:55 AM   #9
ZoominC6's Avatar
Colleyville , Texas
Definitely use one and change it out at least once a year.
Old 08-07-2007, 05:35 AM   #10
1976 25' Caravanner
Campton , New Hampshire
Try putting a gallon of white vinigar in the water tank and then fill the tank . Run this through all the faucets and shower , both hot and cold , using the water pump . Let it sit for several hours or overnight . Empty the tank and refill with good water using a white hose . This is also good for getting rid of the chlorine taste after sanitizing .
ticki2 is offline   Reply With Quote
Old 08-07-2007, 06:00 AM   #11
1974 25' Tradewind
I'm not currently using my fresh water tank as my water pump needs replacing. The water tastes fine before it goe throught the hose (purchased at Wal-Mart) I think it is just because it is a new hose--much like the taste you get with new PVC piping in a new house. Where should I find the in-line filter? I do not even know where to look. Would it be worthwhile to buy one of thoes hose filters that attach between the water hose and the couach water inlet?
Old 08-07-2007, 10:02 AM   #12
FreshAir's Avatar
1966 24' Tradewind
I bought my white hose at WalMart and we aren't having any disagreeable tastes. Of course except for brushing my teeth I don't drink the tank water. Full hook-ups haven't been our problem either. I would say your 'taste' problem is something in your plumbing. When you get the pump repaired flush your system as has been discribed. We take bottled water for drinking but cook with the tap water.
Neil and Lynn
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 08-07-2007, 10:31 AM   #13
ScottW's Avatar
Hernando , Mississippi
Have you tried freezing the water into little cubes and surrounding them with Jim Beam?
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 08-07-2007, 10:40 AM   #14
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Purge the hose well before hooking it to your trailer. If it has standing water in it from the last time then it will have time for the plastic taste to leach into the water in the hose, especially if it's out in the sun. WalMart sells inline RV filters with a charcoal prefilter for taste. About $18, it will last a season with no problem. I will toss mine instead of storing it.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
