Old 08-07-2007, 11:14 AM   #15
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
If you don't find the filter at your local WalMart try
Shop Camping World for RV Accessories, RV Parts, & other items for Outdoor Enthusiasts.
You'll want to remember to flush the new filter of any loose charcoal filtering elements prior to first use. Just push some water through until no black comes out then hook it up and use it.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 08-07-2007, 12:38 PM   #16
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
A standard particle filter won't change the taste, you must use a charcoal filter as described above or similar.
Dave
Fyrzowt is offline   Reply With Quote
Old 08-07-2007, 01:31 PM   #17
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Originally Posted by soldiermedic
You mean I can't use that green hose I been cleaning the gutters out with????
Hey Steve-
Again you got the wrong hose. Use the red one that you used to mix the cement for the patio! All that lyme overpowers the rubber taste!
But on the serious side, as everyone mentioned above, white fresh water hose is the way to go!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 08-07-2007, 03:28 PM   #18
soldiermedic's Avatar
Florissant , USA
To make it easy from campground to campground I just use the water sprayer used to clean the hoses out at the dump station. I just full my tank up and roll out.
I never get sick!
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 08-07-2007, 05:44 PM   #19
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Originally Posted by ScottW
Have you tried freezing the water into little cubes and surrounding them with Jim Beam?
Prefer Jack Daniels Single Barrel myself ,but whatever gets the job done
Roadtoaster is offline   Reply With Quote
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
