Old 03-04-2016, 06:30 PM   #1
1976 25' Tradewind
Loveland , Colorado
Water tanks
Hello, do you have a good vendor for water tanks, fresh and black? I have a 1976 Airstream 25 foot land yacht that has been partly gutted. So we will renovate the trailer and would like new tanks> Also thoughts on Pex piping.
New to renovating a trailer so... help and ideas are welcome.
mbbarnhill2 is offline   Reply With Quote
Old 03-04-2016, 08:18 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello to you from Conifer, CO. Welcome to Air Forums and the vintage Airstream hobby. I'll bet you will find these Forums very helpful as you get started on your renovation of your 1976 25 footer. There will be lots to learn.
My 66 Trade Wind 24 footer had lots of needs when I purchased it 3 years ago. And it still has needs, but we've made progress. I recommend you do a complete analysis of all your trailer's systems so you have a feel for what it will take to get it back on the road again. I like to start from the ground up. Tires, brakes, axles, shocks, belly pan, frame, subfloor, wiring, plumbing, appliances, aluminum body, windows, et. al. Make a list of what's good and what isn't. The 70s trailers do have well known issues with frame rust especially in the rear of the trailer. Make sure you plan to drop the belly plan and inspect the frame for rust.
My trailer didn't have many working appliances, the subfloor was rotted in the rear of the trailer, the plumbing was shot, etc.
Then develop your plan to renovate. Many folks get their old Airstreams "towable" first, meaning good tires, brakes, axles, frame, subfloor and exterior lights. Then they make the trailer water tight. This creates an "aluminum tent" that is somewhat useable with an air mattress and sleeping bag.
Now you can begin the plumbing and wiring projects and restoring old cabinets or making some new ones. Eventually with a lot of time and money, your old Airstream will be like new again.
That said, water tanks are readily available. My 66 needed new tanks all around. I purchased my waste water tanks from Inca Plastics in California. They have a catalog of over 100 tanks. What I did was thumb through the on line catalog until I found a tank with the dimensions and volume I wanted. Inca supplied these tanks in good shape, no problems. I purchased my fresh water tank from Inland Airstream, also in California. The tank they sell was an exact replica of the fresh water tank that was originally in my Trade Wind (which is quite a bit different than your trailer.)
www.incaplastics.com
Post some photos of your old Airstream, we'd like to see it if your willing.
David
Name:	1404 Waste Tanks See Level Senders.jpg
ID:	258153   Click image for larger version
Name:	1404 Plumbing Fresh Tank Rubber Bottom Sheet.jpg
Name:	1505 Home Street Front.jpg
Old 03-14-2016, 11:22 PM   #3
Opelika , Alabama
dbj216, Can you tell us where you got the tank level sensors? Thanks.
racecannon is offline   Reply With Quote
Old 03-15-2016, 06:35 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Sure. The water tank level sensors I used were made and sold by Garnet. I purchased mine from their website:
https://www.garnetinstruments.com/rv-shop/
Hope this helps...
David
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
