Old 08-10-2014, 08:55 AM   #1
2000 27' Safari
Naples , Florida
Water Tank won't fill from outside
We are looking at a 1980 Excella II and the current owner told us the water tank wont fill. They have to be hooked up to use water.
What would cause this? Would it be a bad valve?
Would we have to replace the tank? Typically what would this repair cost?
Thank you!
map-it is offline   Reply With Quote
Old 08-10-2014, 09:01 AM   #2
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
Unless they did something different on this one. Typically the tank water fill has no valve. Just open the door for the water fill and stick the end of the garden hose in.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 08-10-2014, 09:51 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Thank you!
Welcome to the AirForums! Glad to have you with us!
Don't overlook ignorance as a cause. The current owner may not even realize that there is a fill port for the tank separate from the municipal water inlet. If he's trying to fill the tank from the municipal water inlet, then of course it won't work!
It's also possible that the freshwater tank drain valve is open and the owner doesn't realize there's a valve, so that water runs out about as fast as it runs in, so that when filling it won't fill.
Even if neither of those is the reason, until you try to fill it and see what's not working, you won't know. When you go to look at it, try filling it yourself. You may piss off the owner because you're not taking his word for it, but them's the breaks. Better that than buying an unknown problem with an unknown repair cost.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-10-2014, 10:05 AM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Inlet pipe could be plugged, try a shop vac on it or running a coat hangar down it to see if there is an obstruction.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 08-10-2014, 03:04 PM   #5
1964 24' Tradewind
Lawrence , Kansas
Not sure about yours but the tank on my 64 has a vent and it was clogged up. The tank would not fill until I unclogged it.
ttbikes is offline   Reply With Quote
Old 08-10-2014, 06:12 PM   #6
1981 31' Excella II
New Market , Alabama
The fill port is a little flap door on the street side near the wheel well. You open the door and stick the garden hose in the bigger of the two holes and turn on the hose. There is a small hole above the big one that is the vent. Also you have to turn on the pump to use the fresh water tank. If the tank level gages are not working you don't know if the tank is full or not unless you turn on the pump. If the pump keeps running with all the faucets closed and no leaks are in the system then the pump is bad or there is no water in the tank.
The owner is also going to tell you the floor has no rot and there are not leaks which is a lie 99.9% of the time.
Perry
Old 08-10-2014, 10:11 PM   #7
1977 Argosy 28
Irrigon , Oregon
That's good to know about the vent, now just to try and remember that piece of information.
Rod
AIR# 60278
2010 interstate LPG won't fill despite being empty lanzjx2 Airstream Motorhome Forums 4 05-29-2014 11:57 AM
Thetford Aqua Magic pedal push won't fill bowl. handn Sinks, Showers & Toilets 3 02-04-2012 08:07 AM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 12:27 AM
'93 Limited 34' Water Heater won't fill GeraldVG Fresh Water Systems 5 10-23-2008 05:59 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
