Old 01-03-2016, 07:26 AM   #15
Keith Gantt's Avatar
2014 23' Flying Cloud
Woodstock , Georgia
Very detailed quality on your photos and descriptions! I am the same " can do anything guy"and only want it done right.
My 2014 is having tank leak issues and is under warranty but I'm so picky that all my issues I've had over year and a half I have fixed myself.
My tank is often full and towed this way due to off the grid camping. Noticed a dripping from tank area and suspected a issue. After crawling under I found three straps were loose, bolts had pulled threads out and were 1/2 inch out. My tank box is galvanized steel and now was buckled in the center. My guess was it was an installation era not the design. Out of 10 box to frame and 8 strap to frame bolts only 2/yes two couldn't be turned with your fingers. These two ,with a ratchet ,were checked and proved to be "good " with threads in tack. Who ever put the bolts in failed at his job and stripped them out(all but two) on installing them. Give them a power tool without limits and no instructions.... Some good , mores better! As a 35 year service manager and master tech I see this a lot. If my guy does this more than once after instructions ,I fire them.
After retreading to a 3/8 bolt and washer combo reinforcing the brackets to carry the load flat and not to bow the box with a sag in the middle. Straightening the box with 2 by 12 a jack and a hammer I put it all together for now.
With your pictures I have the confidence to remove and repair the tank now as soon as I get a break from using it. ( as well as now I've broken my back in two places and can't physically can't do at this moment) so how much was a new tank? Has anyone looked at getting a custom fab one to fit the box correctly so it doesn't bounce around in a box to big and break stuff? Heat your fill hose with a hair dryer for 2 minutes and the pipe compound softens and slides right off.
Name:   ImageUploadedByAirstream Forums1451831143.650603.jpg
Name:   ImageUploadedByAirstream Forums1451831159.285352.jpg
Name:	ImageUploadedByAirstream Forums1451831170.750714.jpg
The Streaming Gantt's
Keith Gantt is offline   Reply With Quote
Old 01-04-2016, 07:22 AM   #16
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
The new tank cost about $100.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 03-20-2016, 06:59 AM   #17
Woodstock , Georgia
Well, pulled the tank and found Airstream assembly guy fails again. Bolts stripped out that hold tank up which almost caused tank to fail out. Bung for fresh water tank popped off due to over tighten of the elbow in a blind hole.
Name:	ImageUploadedByAirstream Forums1458478711.630553.jpg
ID:	259099Click image for larger version
Name:	ImageUploadedByAirstream Forums1458478732.156468.jpg
ID:	259100Click image for larger version
Name:	ImageUploadedByAirstream Forums1458478757.368912.jpg
ID:	259101Click image for larger version
Name:	ImageUploadedByAirstream Forums1458478768.160545.jpg
ID:	259102Replaced with 3/8 self taping body bolts with built in washers from Ace hardware. Put angle iron on straps to help support tank. Put disconnect on low point drain for easier removal in future. Re insulated tank box. Painted box fox corrosion resistance and foam gasket around bolt surface ( surprise on how much sand was in the box). Heat weld bung from improper installation and urethane over all connections to tank for support with vibrations.
The Streaming Gantt's on Airstream Forums
Old 03-11-2018, 01:34 PM   #18
StagrLee's Avatar
2012 25' FB Eddie Bauer
Was heavily in the Anger part of the Kubler-Ross model until I hit this thread. I got charged for $213 for the same part Alan has for my 2012 EB.
"Stagr" Lee
2012-1/2 25' Eddie Bauer
StagrLee is offline   Reply With Quote
Old 04-23-2018, 02:16 PM   #19
StagrLee's Avatar
My version of the repair. I upgraded the MicroPulse to SeeLevel at the same time. I was thinking about doing at some point but since I was shipped a tank w/o the micropulse fitting on the left, it made me do it now, not later... All in I got charged $300 for the tank with shipping ordered from Camper Clinic II in central Texas. I think I'll be doing parts from Airstream direct as that price seems way high. The collar of the top fill fitting in the tank was also cracked.
Upgraded the tank drain at the same time.
Apparently the fittings cracking is an industry wide problem, not just the Airstream brand. The tank that arrived shipped to my house had block off plugs that we're over tightened from the freaking manufacturer. Good way to sell lots of parts...
ID:	309389   Click image for larger version
"Stagr" Lee
