Old 01-21-2008, 02:42 PM   #1
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Water tank gauge
Our '66 is one year short from receiving tank monitors. Don't need a grey tank gauge...no grey tank. Don't need a black tank gauge...just look down through the toilet. However, the only way to know for sure how much fresh water is on board is when I top it off or the pump runs dry. I don't like to haul a full tank of water if I know some is available at our destination. I do carry a few gallons for 'just in case'. I plan on creating and installing a sight tube in the water supply pipe just after the tank. I can make it viewable by pulling back the gaucho seat back (we have the dinnete gaucho). I have used the 'Search' feature because I thought I remember reading of someone's simular solution but found none. It seems to be easily manufactured with a 'T' fitting and a clear tube the reaches higher, of course, than the height of the tank. Do any of you have knowledge on this? Any cautions? Thanks,
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-21-2008, 03:25 PM   #2
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Water level hose require connection on bottom and vent pipe as well. Do you have easy access to both?
Electric sensors are easy to install if you really want to spend the time.
I am planning to replace my leaky tank with bladder type one.
Cheaper, bigger and very easy to see the water .level.
Is the avatar showing this season snow in Placerville?
Kajtek1 is offline   Reply With Quote
Old 01-21-2008, 03:29 PM   #3
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
In the 1966 sales brochure it says that the International Series have a gauge "on" the water tank and it's optional to all others. I have an International but have never seen this guage. It may be that it's an impression on the water tank itself....hard to say. Is yours an International or?
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 01-21-2008, 03:31 PM   #4
Neil
A sight gauge is the easiest and for next to nothing way to go.
Make sure that it is hooked up to the bottom and top of the tank.
You should always travel with full water.
Full water lowers the center of gravity of the trailer.
Old 01-21-2008, 03:46 PM   #5
Andy....are you saying to travel with full water always (even if you are going to use hook ups), or, just when you travel with water to always be sure it's full?
Old 01-21-2008, 04:52 PM   #6
FreshAir's Avatar
1966 24' Tradewind
It is a Trade Wind Land Yacht. It has twin tanks totaling 35 gals., one under each gaucho (dinnete gaucho) connected to each other by 1/2" pipe. Aparently a PO added a second filler, one for each tank. It doesn't fill that much faster.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 01-21-2008, 04:58 PM   #7
FreshAir's Avatar
1966 24' Tradewind
???...but that is 275+ more pounds on the tongue? We pull much of the time in the Cal. mountains and weight conservation is my concern, not my wifes, however.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 01-21-2008, 05:30 PM   #8
janetb's Avatar
2007 25' Safari FB SE
Santa Cruz , California
Just wondering: Are there baffles in the fresh water tanks to keep the water from sloshing around?
janetb is offline   Reply With Quote
Old 01-21-2008, 05:44 PM   #9
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Not in the tank I just pulled out from my project.
Is there any calculation to what you said Andy? My estimate is, that Safari trailer center of gravity is just couple inches above the floor, while water tank center of gravity is 6" above the floor and there is an issue about impact from water on turns.
Old 01-21-2008, 07:15 PM   #10
The weight of the water in the front tank (originally only had one), does not all go to the tounge.
Some of that weight goes back to the axle as well.
Empty the water tanks and place a scale under the jack post. Fill the tanks with water and see exactly how much tongue weight you have added.
The more weight at the floor line, the better any travel trailer will behave.
Water moving in your tanks when making a turn on the highway, has a neglegible effect on handling, unless you turn city street corners at excessive speeds, and that's not likely.
Traveling cross country with full or empty water has very little effect on fuel mileage. If the trailer is full of water, you will burn up more fuel at a stop light, than the weight of the water will cause. Same for empty water tanks.
Old 01-21-2008, 07:17 PM   #11
FreshAir's Avatar
1966 24' Tradewind
That photo was taken last Feb. We are at 3000' elevation and get snow occassionally. It is snowing at the moment.
Thank you for calling my attention for the need of water level hose connected at bottom AND at the vent. Yes it is accessible.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 01-21-2008, 07:26 PM   #12
FreshAir's Avatar
1966 24' Tradewind
Thank you very much, Andy. The distribution of weight of the tank I did not realize. Also I suspected that our second tank was added. The PO did much boondocking in Oregon. They hunted a lot too evidence of much road dust I cleaned out. Now a water level gauge will be usefull to me by telling me how much water I have left and not how little I can get away with. Thanks.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 01-21-2008, 07:30 PM   #13
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Neil;
Ol buddy ol pal, hey I'll bring my scale to Casini and we can do a real life weight of your rig, with and without H2O!Remember what it was last time we scaled it?
I also have a few spare fitting we use on wing tanks that work like a charm on rotomolded tanks, We use them for sight gauges, might work for water!As long as the tank is vented you just need a 1/2" hole at the bottom and another at the top on the tank. If you need um pronto, you know where to find me.
Or we could set up somethin like a J3 Cub has0 A cork with a stick on it protruding thru the fil cap,Lynn could affix a little AMERICAN FLAG to it for conversation- that would keep her happy!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 01-21-2008, 07:35 PM   #14
The original tank dimensions were 12" x 12" x 52 ". It held 30 gallons of water.
It was immediately under the front window, behind the fold down lounge, and went side to side.
Also the original tanks that were gray, had a huge failure rate. Airstream then changed them to a light green plastic. That too, failed, but not as bad as the original.
The last tank that they used was opaque white, and is still available.
Keep in mind, that with a sight gauge, the water tanks must be level. If not, the sight gauge could show more or less water than you actually have left.
GAS GAUGE / FUEL TANK QUESTION - P-30 Chassis N2XBW Classic Motorhomes 8 12-18-2007 08:38 AM
Tank level gauge. FreshAir Fresh Water Systems 2 07-13-2007 09:55 AM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Black water indicator gauge not working? Ron C Waste Systems, Tanks & Totes 26 06-06-2005 12:35 PM
Propane tank gauge Jim Miller LP Gas, Piping, Tanks & Regulators 6 04-09-2003 04:25 PM
