Old 07-05-2007, 04:35 PM   #1
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Water Tank Fill Door Replacement
Has anyone replaced their fill door and if so what did you use that looked decent. The first photo is what I have - Inca Plastics advised they no longer make the part. It's probably 2 and 1/2 inches square. The second photo is what Airstream advised to replace it with. It's only made in gray - chrome is no longer available - it's about 4 x 6 inches.
ID:	40621   Click image for larger version
Name:	Airstream part 601194.jpg
Old 07-05-2007, 07:42 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Not so fast....
It's still available, just not from Inca. Valterra makes it now, I guess.
RV PARTS OUTLET
cheap, too. You can spray paint it any color with Krylon paint, if you don't want the silly white color.
Uwe
www.area63productions.com
Old 07-06-2007, 07:13 AM   #3
Kintscher's Avatar
2005 19' International CCD
Eugene , Oregon
I really like what Tim from The VAP did on his trailer. I don't know if you can get the fittings to fit though.
1960 Airstream Ambassador Project! Blog Archive More water holes...
Kintscher is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Where can I find a Minuet water filler hatch? Janets Husband Fresh Water Systems 9 05-12-2004 08:45 AM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
