Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 03-03-2006, 02:58 AM   #1
1978 29' Ambassador
bethesda , Maryland
Water Tank Drainage
Does anyone know if a 1978 Ambassador 28' has a water tank drain plug and the location?..I have been draining water at HW drain plug but there has to be a faster way...thanks
popeyedoyle1 is offline   Reply With Quote
Old 03-03-2006, 03:40 AM   #2
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I have a 77 25 footer ,the fresh water tank drain is under the Airstream about 2 foot in front of the axle,there is a square plate,its there,mine has a drain valve,like a water spicket,
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 03-03-2006, 03:58 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
There are also a couple of valves in the back that need to be opened, and at least 2 more under the sink. Maybe someone has access to a manual and can post the full sequence. Do you have an owner's manual? If not you can buy reprints from Airstream these are a nice quality reprint of the orginal owners and service manuals. Well worth the money on the 70's vintage units.
Aaron
WBCCI #XXXX AIR #2495
Old 03-05-2006, 03:44 AM   #4
1978 29' Ambassador
bethesda , Maryland
More 0n water drainage
Thankyou for replies gentlemen....I do have two valves in rear hatch where release valves are located and when I open them I seem to get some drainage...I will check later to see if I have anthing in front of axle...nothing under kitchen sink!!! More Later!!!
Old 03-05-2006, 05:56 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Popeyedoyle,
I don't know if you have a rear bath or center bath...I have attached 2 scans, one for the water systems and one with the winterizing procedures which includes how to drain the entire system. These are from the 1975 and 1976 Owners and Service Manual, so they may not be totally correct for a 1978. You can buy reprints of the manuals from the Airstream Store (bottom of the page) well worth the investment IMHO
Aaron
Old 03-05-2006, 08:19 PM   #6
1976 25' Caravanner
Campton , New Hampshire
Mine did not originally have a drain valve either. Owners manual said to use the pump to drain it. To me it seemed to be a bad idea to use the pump to empty a 50 gal tank.If you take off the 8x8 steel plate under the trailer you should find a 3/8 or 1/2 inch rubber hose . This is the feed from tank to pump. If there is no valve there , cut the rubber hose and put a drain valve in with hose clamps , end of problem. Good luck
ticki2 is offline   Reply With Quote
Old 03-05-2006, 09:29 PM   #7
Coastalview's Avatar
2002 27' Safari
Carmel-by-the-Sea , California
Images: 14
Send a message via AIM to Coastalview Send a message via Yahoo to Coastalview
Water Tank Drainage
If you have a rear bath model like ours, theres a drain plug on the streetside between the axles. Should be plastic, 3/4" head insert to remove, and is within the inside of the water tank belly pan. Jeff
AIR: 649
TAC: CA-40
Northern California Airstreamers
Coastalview is offline   Reply With Quote
Old 03-07-2006, 02:47 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You have a 50 gal tank! I am impressed!
>>>>>>>>>>>>>>>>>Action
Old 03-07-2006, 04:50 PM   #9
1976 25' Caravanner
>>>>>>>>>>>>>>>>>Action
It impressed me also . According to the '76 owners manual all int'l and LY have 50 gal water tank
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
