Old 06-06-2002, 01:49 PM   #1
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Question Water Tank????????
Put all new water lines in and now i think (Know) the water tank is leaking. I know it is under the floor just forword of the axle, but can you get to it from underneath????? I do not want to pull the floor up!!!!!! HELP....
TheBigRedTruck is offline   Reply With Quote
Old 06-13-2002, 11:23 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Drop the belly pan, not the floor.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 06-13-2002, 11:39 PM   #3
83Excella's Avatar
1983 27' Excella
Airstreamville , Kansas
Unhappy Water tank leak
Did you replace the lines to/from the tank? You will likely have to remove the belly covers and drop the tank but start by removing the covers and see what you can
John
83Excella is offline   Reply With Quote
Old 06-14-2002, 10:11 AM   #4
Vagabond
1973 31' Sovereign
Images: 36
Belly pan?????? No i did not replace the lines to/from the tank!!!! How do you get to them, just start pulling the belly apart??????
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
