Old 03-05-2008, 08:30 AM   #1
GREENSBORO , North Carolina
Red face Water tank
I'm looking at a 1972 International. I have not seen it and the owner is telling me that water tank is busted. The unit is a center bath and the tank is somewhere around 4 by five feet. Does anyone know if this is obtainable and if not is it repairable?
VSMITH is offline   Reply With Quote
Old 03-05-2008, 08:40 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
If anyone has it
If anyone has it, it would be Inland RV.
Airstream Parts Sale Inland RV Center, Inc. (951) 734-8130
If they don't then you may be able to repair with a plastic welder or just a soldering gun. That would all depend on how bad it is cracked.
Dan@LED4RV is offline   Reply With Quote
Old 03-05-2008, 08:46 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There are degrees of bustedness that need to be defined. I have a '72 29' and joe somewhen busted off the vent nipple fitting that is an obvious leaker if the trailer is moved with any water in the tank. You need to lie down on the floor and methodically familiarize yourself with it's layout using a mirror and a flashlight to inspect if it is a failed hose clamp or something similar...
Old 03-12-2008, 07:08 AM   #4
1998 30' Excella 1000
HARVEST , Alabama
Replacement parts
I have found that most Airstream parts may be obtained from "Camper Repair Center" Montevallo, Alabama. They have three warehouses filled with Airstream parts, many old ones.
njansen is offline   Reply With Quote
Old 03-12-2008, 08:37 AM   #5
The original water tank for your trailer, has not been available for some time, from Airstream.
We have a replacement made, that is the same size and capacity.
Old 04-14-2008, 08:53 PM   #6
zamboni's Avatar
Hey Andy,
You got a fresh water tank for 79 Moho Excella Classic, center bath. Tank is under roadside rear twin.
zamboni is offline   Reply With Quote
New water pump-? fresh water tank adonh Water Heaters, Filters & Pumps 24 06-19-2008 07:00 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
water leak- hot water tank vent glacierrunne Water Heaters, Filters & Pumps 2 05-29-2006 07:14 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
Water Heater & Water Tank mgordon Water Heaters, Filters & Pumps 23 01-15-2003 06:58 PM
