Old 06-05-2007, 08:39 AM   #1
1991 25' Excella
Dade City , Florida
Question Water System Woes
Have been working to fix up our 1991 25' Excella and have run into a perplexing problem that I think is valve related. I'm hoping that some of you AS experts can help this new AS owner out!
When hooked up to city water my system works perfect, we have hot and cold water on demand. Now the problem -When using the water pump, the water doesn"t flow out of the cold water side but flows out the hot water side, and the water is cold. If I turn the bypass valve at the water heater to the bypass position, the water flows from both the cold side and the hot side and water stays cold. What am I missing here? Could there be a check valve or a bypass valve that I don't know about? Or is this a malfunction of some kind?
Any input would be appreciated,
Ron Tremblay
Dade City, FL
WBCCI # 2245
stillworkinonit is offline   Reply With Quote
Old 06-05-2007, 09:34 AM   #2
7xp
1978 31' Excella 500
Santa Maria , California
Ron
It sounds like your water heater has a bypass system for winterizing. There are posts in the Winterizing and Storage section on this forum. The first post is a sticky and shows the three valves for a bypass system and what position they need to be in. Hope this helps..."Mac"
7xp is offline   Reply With Quote
Old 06-05-2007, 11:02 AM   #3
1991 25' Excella
Dade City , Florida
Unhappy Water system woes
Thanks Mac- but I've checked all the bypass valves and that doesn't seem to be it. With the bypass valve in the "normal" position water does not flow out of the cold water side. With the valve in the "bypass" position it flows out of cold and hot side but doesn't go through the hot water tank, i.e. there's no hot water! Again, this is just running off the water pump, everything works fine if we are hooked up with a hose.
Ron
Dade City, FL
#2245
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
Water Hammer smily Water Heaters, Filters & Pumps 10 02-08-2003 04:18 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
