Old 08-01-2005, 08:10 AM   #1
Water system question
I think I goofed when I re-plumbed my AS. I pretty much had to tear out everything, which is where the question comes in. Does the pressure regulator include a one-way check valve? If so, where can I get a replacement? Or is there another way to accomplish the same thing with off the shelf plumbing parts? It works fine as long as I'm connected city water, but as soon as I pull the hose, the system drains back through the city water connection. Any help would be appreciated. Dave
dld0517 is offline   Reply With Quote
Old 08-01-2005, 08:33 AM   #2
RichardT's Avatar
You can find a check valve at any Home Depot or Lowes in the plumbing department, they are not part of the pressure regulator.
RichardT is offline   Reply With Quote
Old 08-01-2005, 10:09 AM   #3
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
Those pesky valves, when clogged, can make things tough.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-01-2005, 01:46 PM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Any valve
You can buy a gate valve at HD or Lowes or any plumbing supply.
You can even buy them with hose connections. They will thread directly onto your hose fitting and simply close the valve. Voila! no back "spray"
smily is offline   Reply With Quote
Old 08-01-2005, 03:10 PM   #5
FWIW, nowadays, some new regulators have a check valve built in; I noticed this fact when looking at new units to replace my home reg.
joatmon is offline   Reply With Quote
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water leaks Craig Fresh Water Systems 3 08-08-2002 01:44 PM
Water lines in '73 Overlander Bryan Fresh Water Systems 8 06-05-2002 11:42 PM
