Old 08-24-2014, 12:53 PM   #1
2008 31' Classic
Rochester , New York
Water System
We have recently purchased our 2008 AS and have been out a few times for weekends. Twice at KOA's where we had full hookups and twice at state campgrounds where we boon-docked. Last weekend, we sanitized the water system, and then this weekend we were in a state park using the on board fresh water. We won't be going out again for a couple of weeks - again to a state park where we will only have electric hookup. My questions are: 1) fresh water tank - should we drain (about 1/2 full now), 2) having just sanitized, the system should be good for the rest of the year - correct? (assuming we don't accidently introduce something.), 3) how long can the AS safely sit(water safety) between uses?
Thanks ahead of time for replies.
CharlieSK is offline   Reply With Quote
Old 08-24-2014, 01:17 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
My suggestion would be to drain it and re-fill when planning to use it. I really think it would be OK with having sat for a few weeks. If you drink your tank water ( I do sometimes) it will taste better if you drain and put fresh water in. If you don't drink it I don't see it mattering. We usually bring gallons of water from a known source or bought for drinking, making ice or hot tea. I did sanitize my tank on our last trip. Final morning with a partially filled tank I added some bleach and let it slosh around on our trip home.
That's my $.02 and it's almost worth that much.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 08-24-2014, 01:23 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Drain it. It's not that big of deal to refill.
Old 08-24-2014, 01:34 PM   #4
Zil
egg harbor city , South Jersey
As long as there is the proper amount of chlorine in the water, it will be fine and stay fresh. But chlorine breaks down and Stuff grows. Be safe,drain after, and sanitize before each time you use the system, it does not take that long to do..
Zil is offline   Reply With Quote
Old 08-24-2014, 04:12 PM   #5
2008 31' Classic
All,
I drained and we moved to the storage facility. Will pull out in a couple of weeks. Thanks for the replies.
If I think about out normal houses (wood, foundations, don't move) we go away for a couple of weeks and don't worry about the water when we come back. The only time I can remember doing any water system sanitization was when we had a well and sometimes had to dump a gallon of Clorox down the well hole.
Old 08-25-2014, 11:03 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Do not let things freeze!
A full, sanitized and PROPERLY chlorinated tank will not readily grow stuff. Leaving the petcock open can introduce bad stuff. Once drained, close.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-26-2014, 06:43 AM   #7
Rockville Centre , New York
to sanitize what should be used ?
JMBORST is offline   Reply With Quote
Old 08-26-2014, 06:59 AM   #8
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
We use on average 1 gallon water a day 2 people, coffee, tea and cooking. No reason to drink water from a source (tank) that you are not sure of. Why take the chance. Water average 75 cents a gallon.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 08-26-2014, 08:14 AM   #9
retired USA/USAF
2001 30' Excella
To sanitize I put some water in the tank. The amount isn't too important but enough to slosh around. When I did it the other week I think I had something less than half a tank. Figuring about 15 gal. I mixed about 1/2c clorox in some water and added that to the tank before our drive home. After parking the trailer I opened the drain to empty the tank. In retrospect I might have thought to run some water through the sinks just to flow some through the lines but I didn't. When we leave next week again I will simply put some water into the tank and off we go. We do carry a few gallons for most drinking and ice making but I do drink the tank water from time to time. Never have gotten any bugs from it and it tastes better than many hookup sources.
Roger in NJ
TAC - NJ 18
Old 08-26-2014, 08:25 AM   #10
Gainesville , Florida
There are usually directions for sanitizing water on bleach bottle labels. We do not drink the water from the tank but do use it for dish washing, showering and brushing teeth. Sanitizing once a year should be enough. Sometimes if I am topping up the tank I will pout a small amount of bleach in. Remember to use your white hose when filling up. We carry all our drinking water and sodas, etc in an ice chest just for that. Don't remember why, must have been a reason, but I'm too old the recall it. Habit, I guess. Jim
Old 08-26-2014, 08:50 AM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Keep in mind that if you fill your fresh water holding tank with well water (which is our situation at home and also at many campgrounds) you will not have the benefit of any chlorine in your holding tank so the water might not last as long as if it had come from a chlorinated municipal supply.
Bob Martel
WBCCI# 5766
Old 08-27-2014, 07:56 AM   #12
Zil
Bleaching Water Tanks
Search Results
Water Color Change with Bleach
Much information on the Clorox web site.
Cleaning Products, Supplies and Bleach | Clorox
Water Filtration System for Drinking Water kentuvman Fresh Water Systems 6 02-11-2013 08:34 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 06:17 AM
