Old 04-20-2014, 06:00 AM   #1
2014 28' International
Frederick , Maryland
Water shutoff valve - help needed
I just got a 2014 25FB Flying Cloud and am in the process of dewinterizing it. There is water flowing out of this tube and I would appreciate any help in locating the valve. I've located multiple valves, but not the one that controls this. I am assuming that it may be an overflow for the hot water heater since it is right below that area. I've attached a picture of both the tube and the hot water heater.
Thanks!
AirReg is offline   Reply With Quote
Old 04-20-2014, 06:52 AM   #2
1988 25' Excella
Trumbull , Connecticut
Drain
Hello AirReg. I don't think the water heater has an overflow tube. Ar least mine doesn't. That tube is either the drain for the frig or the drain for the AC. Good luck
Happy camping nm1oqrz
Thanks!
Attachment 210065
Attachment 210066
nm1oqrz is offline   Reply With Quote
Old 04-20-2014, 06:57 AM   #3
One other note, when the city water is connected, water comes gushing out of this tube. No problems otherwise.
Old 04-20-2014, 07:07 AM   #4
Plumbing Diagrams - 2014
I am trying to determine why water gushes out of a white tube under where the hot water heater is in my 2014 Flying Cloud 25FB. My manual has plenty of electrical diagrams, but no plumbing diagrams.
Does anyone know where I can get one?
Old 04-20-2014, 07:14 AM   #5
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I believe it's a low point water drain.
If I recall AS started putting a white panel next to the water heater side in the storage bin.
Older (prior to 2014) versions did not have the panel which hides the water heater, and your shut off valve is probably behind that panel.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 04-20-2014, 07:48 AM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I find it hard to believe that with a 2014 Airstream you did not receive an owners manual. I would get one, regardless.
http://www.airstream.com/files/libra...1ff0dca86b.pdf
Old 04-20-2014, 07:57 AM   #7
Fixed!
That worked! Thank you very much.
Old 04-20-2014, 09:32 AM   #8
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Could that have been a drain that was left open from winterizing? Can you follow the tube to a shut off valve?
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Exterior water shutoff valve Ag&Au Fresh Water Systems 14 08-18-2009 09:00 PM
12 volts shutoff then come back on??? dnrtheil Electrical - Systems, Generators, Batteries & Solar 9 05-01-2007 10:54 AM
Is the univolt charger have automatic shutoff? Mrcrowley Electrical - Systems, Generators, Batteries & Solar 2 05-27-2006 03:56 PM
leaky shutoff valve? JohnGalt48 LP Gas, Piping, Tanks & Regulators 0 07-13-2005 06:06 AM
Kohler Fuel shutoff problems rdm Mechanics Corner - Engines, Transmission & More... 5 11-12-2002 07:11 PM
