Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 09-06-2007, 07:29 AM   #1
DanB's Avatar
Profile:  1970 23' Safari
Lorain , Ohio
Water Schematic Review Needed
As my wife would really like to be able to actually use the toilet in our trailer, this weekends project will be to replumb the water system. I have drawn up a schematic for the basic system. I'm planning on using PEX and press-in fittings into a homerun manifold.
I'll attach an image of what I'm thinking abot doing. Any comments or suggestion would be greatly appreciated!
DanB
________________________________
Always Looking for Pinball Machines!
DanB is offline   Reply With Quote
Old 09-06-2007, 09:42 AM   #2
Melody Ranch's Avatar
Profile:  1956 22' Flying Cloud
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 47
Maybe?
How about a water filter?
How about a ready to use winterizing adaptor?
Things I am contemplating for my Caravel.
Old 09-06-2007, 11:46 AM   #3
Profile:
Dan,
Put in a water heater by-pass.
It will really help you with saving on water line anti-freeze.
Turn it on by-pass the water heater when you go to winterize and you will not have to use a TON of anti-freeze.
Oh yeah, like what was pointed out earlier, a filter would be a good addition.
Anon is offline   Reply With Quote
Old 09-06-2007, 12:22 PM   #4
DanB's Avatar
Lorain , Ohio
I had in the bypass, but forgot what it was for!
So now I have two more questions:
-How do I winterize this system? Would it be possible to adapt an air fitting to just blow it out?
-Where should I place a water filter? I have two inlets. I'm thinking directly under the cold water manifold inlet?
DanB
Old 09-06-2007, 01:14 PM   #5
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
You don't need the front fill unless it is a pour fill for the tank and not a connection. You can fill the tank by opening the pump bypass. You do need a vent on the tank, which a pour fill would do. You should include an accumulator to reduce the chance of a water hammer. Depending on how you feel you may want unions on each side of the pump for ease of removal same for the water heater which valves and a bypass would be nice to have. As far as filter you may just want to filter the water to the cold water of the sink as who cares about bath water or use one of the inline filters. I don’t drink water from my tanks or campgrounds we use bottled water for drinking and most cooking.
Thanks Jim
Air # 174
Jim Clark is offline   Reply With Quote
Old 09-06-2007, 01:31 PM   #6
DanB's Avatar
Lorain , Ohio
Thanks for the suggestions so far! Keep them coming, I love this place!
The second inlet is for "pour" and there is vent line present. Putting the filters under the sink would work. No sense filtering bath water.
Regarding the water heater: The press-in fittings can easily be removed, so unions are not neccesary.
Where should I place an accumulator?
DanB
Old 09-06-2007, 01:32 PM   #7
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
in my early-70's safari, there are:
low point drains, in the bath area, and in the galley area, for both the hot line, and the cold line....
an over-pressure relief valve...(which others have said is unneccessary...but airstream thought it was, back then).
check valves after the pressure regulator, and before the pump...
for that reason, blowing out the water with a blow-out plug will NOT protect the pump. actually, you'll never get "all" the water out, anyway, so IMO, best to use a water heater bypass and winterizing kit, which will allow you to draw antifreeze directly from the bottle, into the pump, and through the system.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 09-06-2007, 01:35 PM   #8
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
Some think all incoming water should be filtered to avoid sediment in the water heater.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 09-06-2007, 01:59 PM   #9
Jim Clark's Avatar
That is what the drain valve on the bottom a hotwater tanks is for blow it out once or twice a year. I rebuilt the hotwater heater on my 69 Globetrotter and the tank was clean. Each to his own.
Thanks Jim
Air # 174
Old 09-06-2007, 02:15 PM   #10
Jim Clark's Avatar
boats.com - How To: Water System Installation
Camping World - Shurflo Accumulator Tank
Thanks Jim
Air # 174
Old 09-06-2007, 02:48 PM   #11
thinking outside the box
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
Thank you for asking these questions for me, and doing the schematic too... thank you so much, you have helped me tremendously. My trailer has a bastardized system that is only able to use city water. I want to re-do the entire system and add back in a tank. Boon-docking is our ultimate goal.
Does there need to be a check valve after the city water inlet or does the pressure regulator hold the water back when the pump is pressurizing the system? Is the single arrow symbol a check valve? One last question; is the drain between the tank and the pump needed if the tank itself has a drain?
Frank Yensan The Airstreamer's Club MD-1 founding member "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is offline   Reply With Quote
Old 09-06-2007, 04:08 PM   #12
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Originally Posted by 62overlander
... Does there need to be a check valve after the city water inlet or does the pressure regulator hold the water back when the pump is pressurizing the system? Is the single arrow symbol a check valve? ...
A single arrow is usually a check valve.
Some regulators have a check valve built in to them.
Yes, you need a check valve or water will shoost out of your shore water connection when you are running the water pump without a shore water hose attached.
I have a check valve, but it only seals 99%; I cap the shore water inlet when it is not in use.
Tom
1967 Airstream Overlander International
AL-1
Old 09-07-2007, 06:03 AM   #13
Profile:
Good idea.
Can you imagine what water heaters have to look like on the inside?
Old 09-07-2007, 09:40 AM   #14
DanB's Avatar
Lorain , Ohio
Revised Schematic
I've revised the schematic to include an accumulator adjacent to the pump, but before the check valve.
I've also included a water heater bypass to facilitate easier winterization.
Finally, I've inserted a full system filter. This will require an additional run from the water tank to a tee prior to the manifold, but is probably worth it.
I'm gonna get out the sawzall Saturday. I hope this works
Name:	water revised.jpg
DanB
Help needed: Water heater lighting... Phil and/or Sue Water Heaters, Filters & Pumps 10 03-06-2007 08:27 PM
Hot Water Heater Controler needed NorCal Bambi Water Heaters, Filters & Pumps 2 10-05-2005 01:00 PM
hot water help needed !!!! the welshman Water Heaters, Filters & Pumps 15 06-28-2005 04:04 AM
COLD Water Heater help needed! 1985air345 Water Heaters, Filters & Pumps 3 02-04-2004 06:38 AM
schematic needed! john hd Electrical - Systems, Generators, Batteries & Solar 7 04-07-2003 11:09 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
