Old 05-01-2005, 07:08 AM   #1
Retired and Retreaded
edmatlock's Avatar
1972 26' Argosy 26
1978 28' Argosy 28
Oklahoma City , Oklahoma
Send a message via Yahoo to edmatlock
Thumbs up Water regulator
My '73 31' rear bed has the water regulator under the rear night stand. It has "tripped". Water is running out the over flow hose. Can this be reset or does it need to be replaced or removed?
ED MATLOCK
edmatlock is offline   Reply With Quote
Old 05-01-2005, 12:05 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
It should self reset.
If it does not then it would need to be replaced. You may be able to cap the output as a temp fix. You would need to access the pop off directly and either use a plugged hose (the OEM hose is low pressure) to cap it or remove the output barb and thread in a plug.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Water problems Dbraw Fresh Water Systems 14 10-03-2009 02:15 AM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
