05-12-2014, 09:03 AM
1975 31' Sovereign
brewster
, New York
water pump running on
http://www.shutterfly.com/lightbox/v...2f2841c4d4a52eI pumped RV antifreeze into the water system last fall and recently I was trying to flush it out. The pump is constantly running. Attached is a photo of some type of copper tube with a spring in it. Any suggestions?
05-31-2014, 07:55 AM
1975 31' Sovereign
brewster
, New York
Pump still running on? Sounds like there is some air in system. I let the water run both on pump and water supply. Any other way to purge air from system? I am assuming it is air which is causing to run pump after faucet is shut. Any help would be appreciated.
05-31-2014, 09:05 AM
1976 31' Sovereign
Oswego
water pump
Water heater takes lots of water, open hot water faucet see if helps, if no leaks maybe pressure swt. bad or if original pump time to replace with newer style.
05-31-2014, 09:44 AM
1975 31' Sovereign
brewster
, New York
Thanks. I am going to use the hot water to do some spring cleaning. I will see if letting it run does the trick.
06-01-2014, 03:03 PM
1975 31' Sovereign
brewster
, New York
Water still is coming out in spurts and pump running on. Before I buy a new pump, could this be my problem? I disconnected intake at this point last fall.I don't know what that spring is and if I reassembled correctly?
06-01-2014, 03:41 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I t sounds like you are drawing air from the back side of the pump. (Somewhere between the pump and the tank)
I don't think the spring has anything to do with your issue.
Could one of the fittings be loose ?
06-01-2014, 03:45 PM
1972 31' Sovereign
Benton
, Arkansas
For a test for troubleshooting you could disconnect the hose at the copper fitting and put the pump side in a pan of water to see if the pump will pump cleanly from the pan.
I am assuming that that hose is the pump intake. If it is not, change my instructions to the intake hose.
06-01-2014, 03:53 PM
1976 31' Sovereign
Oswego
water pump
The spring should fit into rubber hose as it will stop from kinking. The spring is not the prob. maybe joint loose when reconnected, as this sounds like pump sucking air then not enough pressure to turn pump off when faucets closed. If pressure swt. bad better off to buy new pump they are not expensive
06-01-2014, 04:20 PM
1975 31' Sovereign
brewster
, New York
I tried disconnecting intake hose and placing it in tray of water. It worked! but for only awhile. I'm thinking it maybe a kink in hose where spring should go, like you mentioned.
06-01-2014, 06:02 PM
1974 Argosy 20
Kooskia
, Idaho
I had a '71 which would not pull water. Turned out that the rubber intake line was pours and when suction was applied to it by the pump, it pulled air in. However it did not leak out. So, a replacement hose did the trick to solve the pump suction issue on that rig.
06-03-2014, 09:05 AM
1975 31' Sovereign
brewster
, New York
pump problem solved
Thanks everyone, it turns out having a full water tank and trailer level helps.
