Old 11-28-2019, 05:02 PM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Water pump check valve source
I want to put a check valve inline with my wp on the output side. Looked at Amazon but everything with f-m connections is in wrong direction. I know I can use a m-m and put a coupling from pump out to cv but wanted to eliminate extra leak point. Does anyone know of a source, that’s reasonable to get a f-m cv with f-m flow direction? Tired of leaking internal cv in pump.
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 11-28-2019, 09:46 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Is the check valve that’s built into your surflow pump not working?
wulfraat is offline   Reply With Quote
Old 11-29-2019, 08:02 AM   #3
Florence , Alabama
It leaks often. First time I removed pump and disassembled head, cleaned everything-there was no obvious debris, just some light tarnish-like stain that I cleaned with paper towel. Put it back and all worked fine. A week or so later it filled fw tank again. I ran pump for ten minutes with cw off and it cleared. It’s done it again, hence the interest in installing a separate cv. I use a water filter from cv faucet so not sure what else to do besides chg the pump. Btw the pump is the shurflo a65 that some rave about. Mine is loud but diff topic
Old 11-29-2019, 08:37 AM   #4
wulfraat's Avatar
I see. I’d just change the pump. They are not that robust. I actually keep a spare with me as several that I’ve owned have failed. They are about $100 bucks.
Could be tricky to insert a secondary check valve the way airstream plumb the connections to the pump....
Old 11-29-2019, 09:33 AM   #5
1976 31' Excella 500
Chappell Hill , Texas
I put a valve after the pump. I close it when on city water.
tbashin is offline   Reply With Quote
Old 11-29-2019, 09:39 AM   #6
MK1EO1
hddeering's Avatar
2020 28' Flying Cloud
Alamogordo , New Mexico
I installed a half inch brass swing check vale on the vertical supply line to the pump.
hddeering is offline   Reply With Quote
Old 11-29-2019, 10:19 AM   #7
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I put my check valve between fresh water tank and the pump instead.
I used this
You can also see it in my FB group located at the bottom of my signature.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 11-29-2019, 10:19 AM   #8
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There should be no difference between putting the valve in front of the pump vs putting it after the pump. If the fittings do not work "after" they should be fine for a valve installed "before". All this assumes the issue is with water *through* the pump. If water leaks out of the pump its self, replace the pump.
Old 11-29-2019, 03:48 PM   #9
Florence , Alabama
Hi
Kinda, but I’d want it after pump to keep force to open on pressure side of pump to not reduce suction. FWIW
Old 11-30-2019, 05:52 AM   #10
Half a Rivet Short
2022 Interstate 24X
Hi
Over the range of pressures that are likely to happen, the delta across the pump would be the same either way and it should work ok.
Old 11-30-2019, 07:33 AM   #11
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I think the check valve should go on the pressure side of the pump, where you want it to. An extra well connected fitting is not going to leak. There are lots of fittings in a trailer anyway. So get what configuration you can and install it.
Rub rail strip insert, door latches, & on-board pump check valve Robere General Repair Forum 4 02-23-2019 04:03 PM
Leak at check valve or water pump. montanablue 1997 - 1999 Safari 16 07-31-2018 07:26 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 06:56 PM
Today gate valve, later check valve. GlenCoombe Classic Motorhomes 1 09-20-2005 11:02 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
