Old 01-22-2014, 10:25 AM   #43
mtbguy's Avatar
Dunwoody , Georgia
I am reading this thread trying to figure out if my Regulator has gone bad. I winterized system last month before a hard freeze that lasted a week. I drained the lines pretty well, but did not drain metal Watts (original factory installed) regulator.
When we went camping this weekend, I filled my fresh water tank and when I turned on the pump, water shot out the side of the trailer where city water hooks up (relief valve I guess). I then hooked up city water to that pipe and used it and the water system worked fine. I forgot to recheck the valve before leaving campsite to see if valve was still stuck open.
Could a hard freeze have ruined the valve, or do they sometime just randomly get stuck?
Rick
mtbguy is offline   Reply With Quote
Old 01-22-2014, 10:29 AM   #44
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Rick
Not the regulator. The check valve, which is supposed to prevent backflow, isn't preventing backflow anymore.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-22-2014, 10:44 AM   #45
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Rick
For a quick fix, if your checkvalve is still sticking open, you can put garden-hose style valve like this Orbit one or this Dramm one. I use one like the Orbit one (from Lowe's or Home Depot) when I discovered the same problem with my '75 Argosy after I fixed a leak in the tank and pressurized the system with the pump the first time instead of hooking up to city water.
It's not automatic, but it's been working for me for 2 years so far.
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | Il Progetto ó 1976 Argosy 28 Center Bath | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 01-23-2014, 06:06 AM   #46
mtbguy's Avatar
Dunwoody , Georgia
I found an extra check valve in a box of random parts previous owner gave me. Will install it, (there is not one in system). Previous owners removed some of the copper pipes, I replaced all with PEX so it looks like I need that valve in place.
I also will use the part that DKB SATX recommends for now. Thanks guys!
