Old 03-12-2013, 09:12 AM   #15
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
I'd have to agree with Protagonist and Sandhill as you are both right. It depends on the design of the device. Some are designed to operate in flowing conditions only. A different design is required to provide pressure control in flowing and static states. I have a long history with this in the O&G industry. It may not be apparent in looking at the valve, but the latter is likely more expensive.
Don
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 03-12-2013, 10:11 AM   #16
1981 31' Excella II
New Market , Alabama
Static pressure is what leads to stress related failures of plumbing systems especially modern plastic systems. A regulator that only works under flow is useless. There are such things as flow restrictors that limit flow for water conservation purposes. Every modern shower head has a flow restrictor.
Perry
Old 05-08-2013, 06:26 AM   #17
1981 31' Excella II
Ok I just called Watts the manufacturer of my new water pressure regulator and they said that the pressure should not creep up to the supply pressure when there is no flow. This behavior is not normal or desired.
Perry
Old 05-12-2013, 10:28 AM   #18
1981 31' Excella II
Sucess finally, I went to Lowe's and returned my $30 Watts water pressure regulator and bought the $70 all metal one and the new one works like it should. As soon as I turned on the water the pressure went to 50 psi and stayed there. I lowered it to 40psi and it is holding steady. It seems that nothing is easy.
Perry
Old 05-12-2013, 11:18 AM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Regardless of what you regulate the input pressure to, the campground anti-reverse valve, or your water pump system, will lock the water in your trailer plumbing, which will then build up additional pressure by thermal expansion, especially the water heater.
There is meant to be some air space in the water heater to take up some of this pressure increase, but it's not always enough. Some of us have added water pressure accumulators to help.
doug k
Old 05-12-2013, 11:28 AM   #20
1981 31' Excella II
You can add an accumulator or a relief valve that will blow at anything over 50psi. You would need a waste dump line to do this so the water has some place to go. Both would be even better. I don't even have the water heater on so my regulator problems were not due to that. You are going to waste a little water with a relief valve but it is better than a flooded trailer.
Perry
Old 05-12-2013, 12:53 PM   #21
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
OK, where is the AS original regulator on a trailer and anyone got a picture of it?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 05-12-2013, 02:20 PM   #22
dznf0g's Avatar
Oswego , Illinois
Just behind the "wall" where the city water inlet hookup is...in your unit....older ones are different.
SHURflo Wall Mount Pressure Regulator Water Entry : Amazon.com : Automotive
Cant see it here...all one piece on the back of this.
-Rich-
Old 05-12-2013, 03:35 PM   #23
GCinSC2's Avatar
Rich,
Never eyeballed it, have to take a look. Thanks.
Gary
S/OS #001
Old 05-12-2013, 04:39 PM   #24
1981 31' Excella II
It would be close to the water inlet. On the center bath units, it is under the closet floor across from the bathroom.
Perry
Old 05-12-2013, 06:26 PM   #25
dznf0g's Avatar
Oswego , Illinois
Perry, Op's is a 2007...the metal remotely installed brass ones were long gone by the 2000s. His (and mine) are plastic and rubber and part of the fill assembly. They often leak...mine did and I resealed it and got an in line external one.
-Rich-
Old 05-12-2013, 06:57 PM   #26
1981 31' Excella II
Here is what I installed.
Shop Watts 3/4-in Bronze Female In-Line Pressure Reducing Valve at Lowes.com=
Perry
Old 05-12-2013, 06:59 PM   #27
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have always used an external regulator. I hook it up first, next to the city water valve. In my mind I may be protecting my hose as well.
Old 05-12-2013, 07:02 PM   #28
dznf0g's Avatar
Oswego , Illinois
Originally Posted by perryg114 View Post
I got a similar Watts unit, but already had fittings and a gauge fitted. Mine is external and inline before the AS city water inlet. It rests in the belly wrap compartment and the hose exits through a "door" in the bottom of the compartment.
-Rich-
