Old 06-16-2010, 08:56 AM   #1
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Water Pressure Regulator in '71 Safari?
I'm starting to check out and as necessary work on the fresh water systems in our '71 Safari. Does anyone know if there is a water pressure regulator in the '71 Safari? The manual says there is one in the back corner of the trailer, but I can't find it.
If a pressure regulator isn't present in the water system in the Safari is there a unit you recommend I add externally or should I add it internally?
Thanks!!
- David
1971 23' Airstream Safari - "Moe"
2017 Ford F350 4x4 6.7 CCLB - Silver/Black - "Max"
pickerdd is offline   Reply With Quote
Old 06-16-2010, 09:00 AM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
My '70 safari has one in the "trunk". It was plumbed very rough, but worked.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 06-17-2010, 08:34 AM   #3
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks for the info Dan. Do you by chance have a photo of the location of the regulator? I'm hoping mine will be located in a similar location as yours.
Thanks!
- David
Old 06-17-2010, 08:59 AM   #4
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Sorry, I don't have a pic, but thru the rear access door, my black tank is directly above the plywood floor to the streetside. The black tank was elevated about an inch with blocking. This allowed the city water line to pass under the tank. The regulator was right next to the tank. It is a round, brass device about 4 inches in diameter and a couple of inches high.
Please note that the previous owner had done some modification for filling and filtering. What I had may not have been original.
DanB
www.campnova.com
Old 06-17-2010, 09:19 AM   #5
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks. I'll check that area of my Safari. I don't have the access door on the back of my Safari, but with yours as a guide I should be able to find it. Have you had to replace your regulator?
Thanks!
- David
Old 06-17-2010, 09:27 AM   #6
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
No access door? I'm talking about a large door above the rear bumper. This is where my batteries are.
Anyways, I reused my old one. Truthfully, I'm not sure if it works or even how to test it! I just plumbed it back inline.
DanB
www.campnova.com
Old 06-17-2010, 10:02 AM   #7
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Although mine is a 71 Caravel I would think yours was in the same area. Mine was in the rear behind the water heater. No access whatsoever. I rearranged the plumbing and installed a water fill on the street side and moved the regulator to this location under the side couch.
Name:	71 <a title=Caravel Water System 4.JPG Views: 99 Size: 276.0 KB ID: 105085" style="margin: 2px" />
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 06-17-2010, 10:51 AM   #8
howco's Avatar
1970 27' Overlander
Sumner , Washington
Twaugh, very nice work, I like the fact that all is out in the open and accessible......
I call this 'perfect plumbing...
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 06-17-2010, 11:43 AM   #9
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
Thanks for the info. My '71 Safari doesn't have an access door above the bumper. I wish it did! I have a door on the curbside rear where my battery is stored, which also is where the univolt was located and a door near the rear street side for the water heater.
Thanks for the assist.
- David
Old 06-17-2010, 11:48 AM   #10
pickerdd's Avatar
1971 23' Safari
Marietta , Georgia
TWaugh,
Thanks for the photo. I'll take a look under the street side mattress and check next to the water heater. I bet it's there. It's been a while since I looked under there.
Thanks again for everyone's help!
- David
Water pressure regulator? yukionna Fresh Water Systems 7 06-16-2010 10:03 PM
Is the water pressure regulator really necessary? page.crow Water Heaters, Filters & Pumps 17 05-02-2009 03:18 PM
water pressure regulator leak. kss Plumbing - Systems & Fixtures 1 01-15-2009 09:25 PM
Water pressure regulator IndyAnne Fresh Water Systems 14 04-15-2008 12:26 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
