Old 09-22-2011, 08:53 PM   #1
2012 28' International
Perris , California
Water pressure regulator
Took our new 28' International out on its first trip, and our fresh water hose got damaged from water pressure - the hose is all "puffed up.". We didn't use one of those brass water pressure regulators because the dealer said the Airstream has a regulator built-in and that putting an external one would lower the water pressure.
I'm guessing this is just a bad hose (it's the one that came with the starter kit)?
ArchieGates is offline   Reply With Quote
Old 09-22-2011, 09:03 PM   #2
Ottawa , ON
Some travellers use a regulator to protect the white hose. It goes on the water supply tap, then the white hose goes onto it.
You just found a good reason to use that kind of hookup.
Old 09-22-2011, 09:28 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Lower the pressure? TRUE, would you notice? I doubt it. The installed regulator the dealer talks about is set very low so the additional one in line before the hose is generally a higher pressure rated regulator and will do as described - protect the hose.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-22-2011, 10:12 PM   #4
St Cloud , Minnesota
Or it could just be a defective hose that ballooned up from a casing leak. The 10 footer I started out with - probably a Camco - worked fine for a few months and then inflated like a sausage. I had a regulator on the hydrant and I don't think the problem was the water pressure. My current hose has been in constant use for several years with no problems; it cost a bit more than the Camco.
JamieEllis is offline   Reply With Quote
Old 09-23-2011, 09:30 AM   #5
Perris , California
Thanks for the feedback! I'll try a pressure regulator before the new hose to see if it affects water pressure.
Old 09-23-2011, 07:55 PM   #6
1981 31' Excella II
New Market , Alabama
It is always a good idea to have some sort of pressure gage down stream of the regulator so you can tell if it is working properly. I have seen some fail open.
Perry
1962 Tradewind water pressure swainee Waste Systems, Tanks & Totes 4 07-19-2011 09:04 AM
Pressure Regulator Needed? DKDarrow Fresh Water Systems 4 07-14-2011 07:04 PM
Another Water Pressure Question lsmith Fresh Water Systems 3 04-03-2011 10:20 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 01:00 PM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 02:50 PM
