Old 03-13-2011, 11:53 AM   #1
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Water Pressure Regulator
I came across this water pressure regulator. It looks like it would work great. Preset to 40 psi and made of brass and stainless steel. Attaches to the faucet or one could attach it to the hose connection on the trailer.
It's not cheap $57.75 but could save your system if the internal one fails.
It is sold by Gemplers; the part #192109.
Just click on the picture, it will take you to their web site.
Old 03-13-2011, 12:02 PM   #2
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
I checked the Watts site and in the specs it says it also decreases the flow. Typically the flow reduction is a common problem on water pressure regulators designed for RVs. It would be nice to know how much the flow is reduced by this regulator.
I built a water regulator for use on the RV by purchasing a standard regulator designed for residential use (N45B Water Pressure Reducing Valves , Water Pressure Reducing Valves - Standard Capacity, Water Safety & Flow Control - Watts). You have to add a few parts to add hose connections but it is pretty easy. The total cost was around $40 or so. You can get the regulator and adapters from either Home Depot or Lowes.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-13-2011, 01:14 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Rating
The specs on it say 4gpm or 240gph, more than enough for an RV. It would fill a 6 gallon water heater in 1.5 minutes. Most of the new shower heads and faucets limit flow to 2gpm.
Old 03-13-2011, 01:18 PM   #4
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
This is Winning..
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 03-13-2011, 01:27 PM   #5
1973 31' Excella 500
Spring Green , Wisconsin
By definition, the quantity of flow is reduced when the pressure is reduced. The flow through a conduit is calculated by multiplying the velocity by the cross sectional area of the conduit and is normally stated in gallons per minute. Pressure reduction results in a lower velocity and reduced flow. The water pressure is what moves the water through the conduit.
If you buy one of these, I'd be interested in what pressures you experience at various campgrounds. Unless you camp in very hilly or mountainous camprgrounds, I'd be surprised if you encountered more than 40 psi at the connection. I've designed many public and private water distribution systems in the past 40 years and, more often than not, the challenge is to provide adequate pressure in an ecomical system rather than reduce pressure to an allowable level.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Another Water Pressure Question lsmith Fresh Water Systems 3 04-03-2011 09:20 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
Discovered how to increase water pressure! HCR Fresh Water Systems 6 01-15-2011 01:50 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
