Old 08-20-2005, 02:29 PM   #1
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Water pressure regulator?
Does anyone know what this is and how to use it? It is on the outside of my 1954 Safari and looks to be related to water pressure as it has a hose fitting on the bottom and a valve stem and gauge on top.
Name:	water inlet 1.jpg
ID:	14053   Click image for larger version
Name:	water inlet 2.jpg
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 08-20-2005, 02:42 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
1954? Since a Shraeder valve is present, I am guessing that you are looking at a pressurized water delivery setup (as opposed to a demand pump).
The Shraeder valve allows you to pressurize the tank at a gas station. Or at least the stations of old. The gauge allows you to see what the tank's pressure is.
Like I said, its a guess.
Tom
Old 08-20-2005, 02:43 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
That is what is used to provide water pressure to the coach when dry camping. You pumped up the tank with bicycle tire type pump. Does that coach have a 12volt system? IIRC they did not or they were optional.
Aaron
WBCCI #XXXX AIR #2495
Old 08-20-2005, 06:36 PM   #4
yukionna's Avatar
Massachusetts
Images: 18
Aaron
No, my coach doesn't have a 12 volt system.
WBCCI Region One
Old 08-20-2005, 06:47 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Okay that is it. That is your pressurized water system. All/most RV's I have ever owned have been the dual voltage systems. I had one old slide in pickup camper that did not. It had LP only and had the pump up pressure system similar to what you are seeing, except the pump was built into the camper.
Aaron
Old 08-21-2005, 12:28 AM   #6
yukionna's Avatar
Massachusetts
Images: 18
Upon further investigation, I found another thread with more information on this same topic. The thread further confirms that my '54 has a "pressure-type" water system as opposed to the "demand-type" system. Another indication that this is a "pressure-type" is that the water tank is made of metal and the city water connection and water fill are the same connection whereas in a "demand-type" system, the tank is made out of plastic and the city water and water tank fill connections are separate.
WBCCI Region One
Old 08-21-2005, 12:47 AM   #7
yukionna's Avatar
Massachusetts
Images: 18
In yet another thread, I found more good information from 59toaster:
The way the system worked is you could fill the tank by the inlet on the curb side front. You could pressurize the system with about 60PSI of air. If your miserly with your water usage that was "supose" to last about 2 days. You could pressurize and fill by connecting to the city water connection. Water would back flow into the tank and pressurize at the same time. Problem is depending on the water pressure on the line filling, you might only get 20 gallons of water in before your couldn't overcome the built pressure in the tank.
WBCCI Region One
Old 06-16-2010, 10:03 PM   #8
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Know its an old thread, but discovered the 63 sov. I picked up today has one of these pressure units inside, haven't investigated, but very cool.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Bowen Pressure relief valve melprice Water Heaters, Filters & Pumps 5 06-16-2002 06:47 AM
